    Refresh modules / MagicMirror without running pm2 restart?
    17 Posts 4 Posters 5.5k Views 4 Watching
    • C Offline
      cotxwx @sdetweil
      @sdetweil Good to know, thank you. I’ll start looking in to my FW logs and see if something stands out. I really appreciate you taking the time to do this.
      • C Offline
        cotxwx
        Well, temporary workaround for anyone having a similar issue…
        Installed xdotool and created a shell script to “press” ctrl+r every hour. Now it’ll just refresh itself at the top of the hour.
          sdetweil @cotxwx
          @cotxwx weird. i can’t get mine to stall…
          • P Offline
            Privacywonk @sdetweil
            @cotxwx I am experiencing the same issue. Do you by chance turn your mirror monitor off? Mine is hooked up to a TV HDMI input and the issue seems to present itself when I switch between HDMI inputs…
              sdetweil @Privacywonk
              @Privacywonk hm. I don’t see that at all.
              I have 4 different devices running mm attached to the 4 HDMI ports on my tv, and don’t see any behavior problems switching
              Pi4 (4k)
              pi3 (1080p)
              pi0 (1080p)
              and
              jetson nano (4k)
                RJDaPirate
                I’m experiencing the same issue with my MM. Module worked fine for weeks not won’t last an hour before the Rain Radar Module goes dark.
                  sdetweil @RJDaPirate
                  @RJDaPirate when it goes dark, open the developers window ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                  you can also filter messages by module, by putting part of the module name in the filter field, rain, for example
                  let us know
