    Refresh modules / MagicMirror without running pm2 restart?
    17 Posts 4 Posters 7.2k Views 4 Watching
      cotxwx
      I will grab that next time it locks up. Thanks!
        cotxwx @sdetweil
        Is there something specific I should be looking for here? It just locked up and this is all I see.
          sdetweil @cotxwx
          @cotxwx hm… I have it loaded too… we shall see
            cotxwx @sdetweil
            @sdetweil If you haven’t had this issue before, that pretty much rules out the module itself, I’d guess. I do have a FW at my egress, with some DNS block lists. It doesn’t seem logical that it would load initially, but fail an hour or two later, but I’ve seen weirder.
            (Unless, of course, you’ve just loaded it. In that case, ignore my last statement).
              sdetweil @cotxwx
              @cotxwx just loaded for 1st time ever…
              have fixed a few things already… my system does module hiding for screen sleep…
              it doesn’t… added error handler for the case I think is the problem… we will see…
                cotxwx @sdetweil
                @sdetweil if you’ve just loaded it, watch out for “updateOnWarning:” in the config.js - If you don’t set it to ‘0’, the entire module disappears if there are no active warnings in your area. I learned that one the hard way. :)
                Thanks for the assistance!
                  sdetweil @cotxwx
                  @cotxwx hm… mine is showing, did not set that variable
                    sdetweil @cotxwx
                    @cotxwx mine has never stopped working and never reported an error
                      cotxwx @sdetweil
                      @sdetweil Good to know, thank you. I’ll start looking in to my FW logs and see if something stands out. I really appreciate you taking the time to do this.
                        cotxwx
                        Well, temporary workaround for anyone having a similar issue…
                        Installed xdotool and created a shell script to “press” ctrl+r every hour. Now it’ll just refresh itself at the top of the hour.
                          sdetweil @cotxwx
                          @cotxwx weird. i can’t get mine to stall…
                            Privacywonk @sdetweil
                            @cotxwx I am experiencing the same issue. Do you by chance turn your mirror monitor off? Mine is hooked up to a TV HDMI input and the issue seems to present itself when I switch between HDMI inputs…
                              sdetweil @Privacywonk
                              @Privacywonk hm. I don’t see that at all.
                              I have 4 different devices running mm attached to the 4 HDMI ports on my tv, and don’t see any behavior problems switching
                              Pi4 (4k)
                              pi3 (1080p)
                              pi0 (1080p)
                              and
                              jetson nano (4k)
                                RJDaPirate
                                I’m experiencing the same issue with my MM. Module worked fine for weeks not won’t last an hour before the Rain Radar Module goes dark.
                                  sdetweil @RJDaPirate
                                  @RJDaPirate when it goes dark, open the developers window ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                  you can also filter messages by module, by putting part of the module name in the filter field, rain, for example
                                  let us know
