    Is it possible to have CSS for normal screens and a custom CSS for 7in screen?
    32 Posts 3 Posters 9.5k Views 3 Watching
      sdetweil @Radnor
      @Radnor see my comments above workaround for not defined at node_module load time
        sdetweil @Radnor
        @Radnor css and config.js are different things… no way to change the filenames of the css files…
          Radnor
          Getting really close!
          My config file is:
          var small_size = 800;
          var width = 0;
          try {
          	width=outerWidth
          catch(error){
          SNIP
          			module: "newsfeed",
          			position: "bottom_bar",
          disabled: width > small_size ? false:true,
          SNIP
          On phone does not show. On laptop stuck at “Loading…”
            sdetweil @Radnor
            @Radnor said in Is it possible to have CSS for normal screens and a custom CSS for 7in screen?:
            because width =0
            0 > 800 is false, so disabled=true
            when loading the node_modules, so it doesn’t get loaded
            try
            var width=801
            the node_helper might get loaded, but won’t execute cause they are waiting for module to send parms
            the value will be corrected on browser side
              Radnor @sdetweil
              @sdetweil said in Is it possible to have CSS for normal screens and a custom CSS for 7in screen?:
              because width =0
              Dont think so. I started it up with DEV option. Loaded the config.js file in debugger hovered over the width and it showed 1280. Then hovered over the small_size and it showed 800. Then thought false and true might need double quotes because the rest in config has t/f in double quotes.
              Thank you for sticking with me and getting this working I really appreciate your time. it is SO close.
                Radnor
                I put in config width =801 and reran it. Same “Loading …”
                And commented out try - catch block.
                  sdetweil @Radnor
                  @Radnor single or double quotes don’t matter, as long as both ends of the string have the same
                  I just set my code to
                  var width	= 1920  // make it so on big screen they get enabled
                  try {
                    	width=outerWidth
                  catch(error){
                  var large_screen=1920  // expected size on computer
                  and the test for calendar at
                  			disabled:    width< large_screen?true:false, // if the current screen is smaller than computer, disabled
        // you can flip too,  ?false:true
                  			header: "US Holidays",
                    @Radnor I had to fix the size for node_helper loading…
                    I have them enabled if big screen, disabled if small screen
                      @sdetweil better
                      var width	= 801
                      try {
                        	width=outerWidth
                      catch(error){
                      var small_screen=800
                      and module disabled
                      			disabled: width>small_screen ?false: true,
                        Radnor
                        OK, I think the disabled has something to do with the newsfeed.
                        I have several config files. config_WORKING has modules alert, notify, clock, wx, wx forecast, calendar, and newsfeed.
                        I have config_CLOCK with modules clock, wx, and wx forecast. In this config I told it via disable: width > small ? false:true. On my laptop get all 3. on phone no forecast (which should not be there).
                        In the newsfeed module the disable test is messing it up.
                        I rename either WORKING or CLOCK to just config.js to test.
                        • 2 / 4
