    Is it possible to have CSS for normal screens and a custom CSS for 7in screen?
    32 Posts 3 Posters 11.1k Views 3 Watching
      sdetweil
      @Radnor said
      I have config_CLOCK with modules clock, wx, and wx forecast. In this config I told it via disable: width > small ? false:true. On my laptop get all 3. on phone no forecast (which should not be there).
      I see 4 things in the list
      on phone, no forecast, which is not an error?
      i set my newsfeed to
      			module: "newsfeed",
      			disabled: width>small_screen?false:true,
      see on desktop, not on phone, as expected
        Radnor
        There’s 3 (wx forecast) is forecast. Not weather AND forecast.
        No error because in forecast was disabled because of small screen.
        I copied your 2 lines (newsfeed & disabled) and get error when starting it. Complains about my config file…
        Any way of letting it load up and do a display:none in the CSS file for small screen?
          sdetweil @Radnor
          @Radnor notice my variable names (small_screen) are not the same as yours… (small_size)
            Radnor
            Initially, I did NOT see the different variable name.
            Cannot get the Ternary op to work at all. I copy/paste (and change var name) your code without luck.
            A straight “disabled: true” works.
              sdetweil @Radnor
              @Radnor its a (if) ? when_true : when_false
              show me your code now
                Radnor
                var small_size = 800;
                var width = 0;
                try {
                width=outerWidth
                catch(error){
                var config = …
                		module: "newsfeed",
                disabled: width < small_size ? true:false,
                position: “bottom_bar”,
                I had it WITH and WITHOUT the comma after false. I had parens around the logical test too.
                  Radnor
                  Event tried:
                  if (small_size>width) {
                  disabled: true,
                  this generates error in config with lots of red text on loading up
                    sdetweil @Radnor
                    @Radnor gotta have the comma after, cause there is more to this module definition… (, comma means more info following this line)
                    so, u want news feed ON for laptop (disabled:false), OFF for small display (disabled:true)
                    so, newsfeed has two parts… the node_helper, and the browser part (modulename.js)
                    so, we WANT the node_helper to load (disabled:false), but don’t know anything about the screen size yet, so it must be ALWAYS disable:false
                    var width = 801;   // notice 1 larger than expected size of small screen
                    try {
                        width=outerWidth        // get the actual screen width (only works in browser usage)
                    catch(error){                       // this catches the fatal error in node_helper loading
                    config info
                    		module: "newsfeed",
                                    disabled: width > small_size ?        // on startup, this will be true, so we want disabled:false
        // when the browser on laptop pulls in modulename, this will be true
        //              so disabled: false
        false:
        // when the small device is used, this will be false (800 is NOT greater than 800)
        // so we want disabled: true
        true
        ,     // more stuff coming on next line
                      Radnor
                      Thank you.
                      I’ve had it with and without the ending comma. Your changes, I’ve put in config.js only (node helper???) I did not put it in the modulename.js
                        sdetweil @Radnor
                        @Radnor said in Is it possible to have CSS for normal screens and a custom CSS for 7in screen?:
                        you do NOT put it into anything other than config.js,
                        the system (MM) will load config.js
                        once for loading node_helpers
                        once for each browser that connects to MM (including one that is included when npm start is done)
                        • 3 / 4
