    Raspberry Pi 3 b+ and Magic Mirror
    5 Posts 4 Posters 4.2k Views 5 Watching
    • L Offline
      lehoang
      Hi everyone,
      I’m a new user and I apologize if this isn’t the right section.
      I was wondering if there’s a chance to make the magic mirror work on the new raspberry pi 3 b+. I just ordered the new version with the idea ok making my mirror but I don’t know how to start.
      Hope you can help me.
      FoziF 1 Reply Last reply Reply Quote 0
      • P Offline
        pandeyprakhar00
        You can start with setting up your raspberry pi first and arrange a screen (with HDMI) so that you can start the software part.
        This tutorial will help you setting up the raspberry pi in headless mode - (Without Ethernet cable & Monitor)
        https://www.youtube.com/watch?v=wqKCPbu7V7Y&t=7s
        Secondly, i recommend adding a fan to your pi, because Rpi 3b+ heats up a lot.
        https://www.youtube.com/watch?v=srMnIcQvDn0&t=89s
        Once you pi is ready with a fresh copy of Raspbian install MM & pm2
        Configure your modules… and you are ready to go !
        For hardware portion of the mirror you can take idea of my Frameless mirror !
        https://www.youtube.com/watch?v=sCetiJk2Qus&t=68s
          sdetweil @pandeyprakhar00
          @pandeyprakhar00 said in Raspberry Pi 3 b+ and Magic Mirror:
          please use the installation script for this
          see here https://github.com/sdetweil/MagicMirror_scripts
          read the readme for the comnmand to issue
          • FoziF Offline
            Fozi Project Sponsor @lehoang
            @lehoang A Pi 3b+ is totally sufficient and probably 90% of all MMs use it. Then apply @sdetweil script and you’re in the game.
            • P Offline
              pandeyprakhar00
              I have made a video tutorial about how to install MM application using @sdetweil scripts. I have also tried to explain the module configurations ! Hope it would help you…
              https://youtu.be/PHpth_KQHcE
