    Cooling Raspi
    19 Posts 6 Posters 5.7k Views 7 Watching
      requiemmg
      https://www.ikea.com/de/de/p/ribba-rahmen-schwarz-50268874/ Standard IKEA frame, replaced the front with a 8 mm ChromeSpy glass.
      • P Offline
        pandeyprakhar00 @requiemmg
        @requiemmg Actually there is a hack! You can increase the space between wall & frame by placing 4 no screws in the back side of frame that would give you some extra margin to place your fan on Rpi. You can also adjust the screw height accordingly! Hope it helps !
          requiemmg
          Thanks. Have a case now with passive cooling that fits, Temp around 48°C.
          Unfortunately, it still freezes and I dont know why, will open a new thread for this.
          FoziF 1 Reply Last reply Reply Quote 0
          • FoziF Offline
            Fozi Project Sponsor @requiemmg
            @requiemmg when it freezes at 48C then it’s no cooling issue. Try another SD card, maybe that’s the cause.
            • BKeyportB Online
              BKeyport Module Developer
              FYI, there’s plenty of fan PiHats to make it super easy to cool your Pi.
                requiemmg
                I found a passive cooling case (this one: https://www.reichelt.de/gehaeuse-fuer-raspberry-pi-3-aluminium-schwarz-rpi-case-alu-3b-p248738.html?&trstct=pos_0&nbc=1) which has a nice cooling effect behind a ikea frame. Raspi not warmer than 55°C.
                Still, I have freezing problems, but this is totally unrelated…
                • BKeyportB Online
                  holy damn, I feel like my CPU is absolutely frigid then. I run at 35-40c…
                  • BKeyportB Online
                    here’s my solution: https://www.amazon.com/gp/product/B07WMTNXZ1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 - because my pi is behind a frame, I pulled the LEDs off the backside…
                    • karsten13K Offline
                      karsten13
                      for raspi 4b, very clean solution and easy to open:
                      https://joy-it.net/en/products/RB-CaseP4+03B
