    Cooling Raspi
    19 Posts 6 Posters 7.1k Views 7 Watching
      pandeyprakhar00
      I am also using my mirror with Rpi3b+.
      To avoid overheating of pi, a Heat Sink & Fan is enough to maintain temperature below 50 Deg C.
      But as you quoted that the pi is without a case you could use cable ties to attach it to your fan just like this guy did !
      https://www.instructables.com/id/Simple-Raspberry-Pi-Cooling-Fan/
      Secondly, you can also make the fan automatic so that it does not runs forever ! This link below demonstrates how i did it for my own Magic Mirror !
      https://www.youtube.com/watch?v=srMnIcQvDn0&t=88s
      You could also decrease the speed of fan by decreasing its potential so it does not make any noise.
      My mirror works 24 X 7 and it never freezes !
      Check my built here : https://www.youtube.com/watch?v=sCetiJk2Qus&t=68s
      • FoziF Offline
        Fozi Project Sponsor @requiemmg
        @requiemmg I’m running my RPi 3B+ just with stock heat sinks and the temperature is always at 60-61 C. This temperature is not really worrying, rather normal. What might happen is that it may start throtteling from 1400 MHz to 1200 MHz when it excedd 60C. There have been some changes in Raspbian in the last years where the temperature limit was set from 70 to 60 C for throtteling and then changed back again. What you could do is raise the throtteling temp to 70 with following entry in in /boot/config.txt:
        temp_soft_limit=70
        But the Pi shouldn’t freeze at any of these temps. When it freezes, then usually when the memory ran up due to a memory leak. There might be some modules around which handle memory allocation a bit sloppy. As a workaround you can setup a cron job to reboot the Pi regulary, e.g. every 6 or 8 hours for example.
          requiemmg
          Thanks for your hints.
          Well, it does freeze at these temperatures. And I already have a cronjob which reboots the pi every 6 hours, does not help. No freezing when cooling with a fan, but far too noisy, so no, doesnt seem to be a memory problem rather than a heating problem, so I do not think that setting up higher throtteling temperatures will do any good.
            sdetweil @requiemmg
            @requiemmg why too noisy? I never hear the fans on both my pi 3, pi4 and jetson nano on the other side of the room (6 ft away)
              requiemmg
              AS I have no case, I have no way to fix the fan without touching anything and then it is scratching on the surface or is vibrating. Tried it a lot, always too loud. No idea on how to get it fixed.
              S P 2 Replies Last reply Reply Quote 0
                sdetweil @requiemmg
                @requiemmg buy a case… cheap
                  pandeyprakhar00 @requiemmg
                  @requiemmg
                  Try this if it helps to hold the fan !
                  Try this if it helps !
                    requiemmg
                    I have several cases here, that’s not a problem. There is not enough space between frame and wall.
                      @requiemmg can you share photograph of the frame ? It would be easy to visualize. ! may be i could be of any help…
                        requiemmg
                        https://www.ikea.com/de/de/p/ribba-rahmen-schwarz-50268874/ Standard IKEA frame, replaced the front with a 8 mm ChromeSpy glass.
                          @requiemmg Actually there is a hack! You can increase the space between wall & frame by placing 4 no screws in the back side of frame that would give you some extra margin to place your fan on Rpi. You can also adjust the screw height accordingly! Hope it helps !
                            requiemmg
                            Thanks. Have a case now with passive cooling that fits, Temp around 48°C.
                            Unfortunately, it still freezes and I dont know why, will open a new thread for this.
                            • FoziF Offline
                              @requiemmg when it freezes at 48C then it’s no cooling issue. Try another SD card, maybe that’s the cause.
                              • BKeyportB Offline
                                BKeyport Module Developer
                                FYI, there’s plenty of fan PiHats to make it super easy to cool your Pi.
                                  requiemmg
                                  I found a passive cooling case (this one: https://www.reichelt.de/gehaeuse-fuer-raspberry-pi-3-aluminium-schwarz-rpi-case-alu-3b-p248738.html?&trstct=pos_0&nbc=1) which has a nice cooling effect behind a ikea frame. Raspi not warmer than 55°C.
                                  Still, I have freezing problems, but this is totally unrelated…
                                  • BKeyportB Offline
                                    holy damn, I feel like my CPU is absolutely frigid then. I run at 35-40c…
                                    • BKeyportB Offline
                                      here’s my solution: https://www.amazon.com/gp/product/B07WMTNXZ1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 - because my pi is behind a frame, I pulled the LEDs off the backside…
                                      • karsten13K Offline
                                        karsten13
                                        for raspi 4b, very clean solution and easy to open:
                                        https://joy-it.net/en/products/RB-CaseP4+03B
