    Cooling Raspi
    19 Posts 6 Posters 6.0k Views 7 Watching
      requiemmg
      AS I have no case, I have no way to fix the fan without touching anything and then it is scratching on the surface or is vibrating. Tried it a lot, always too loud. No idea on how to get it fixed.
      S P 2 Replies Last reply Reply Quote 0
        sdetweil @requiemmg
        @requiemmg buy a case… cheap
          pandeyprakhar00 @requiemmg
          @requiemmg
          Try this if it helps to hold the fan !
          Try this if it helps !
            requiemmg
            I have several cases here, that’s not a problem. There is not enough space between frame and wall.
              @requiemmg can you share photograph of the frame ? It would be easy to visualize. ! may be i could be of any help…
                requiemmg
                https://www.ikea.com/de/de/p/ribba-rahmen-schwarz-50268874/ Standard IKEA frame, replaced the front with a 8 mm ChromeSpy glass.
                  @requiemmg Actually there is a hack! You can increase the space between wall & frame by placing 4 no screws in the back side of frame that would give you some extra margin to place your fan on Rpi. You can also adjust the screw height accordingly! Hope it helps !
                    requiemmg
                    Thanks. Have a case now with passive cooling that fits, Temp around 48°C.
                    Unfortunately, it still freezes and I dont know why, will open a new thread for this.
                    • FoziF Offline
                      Fozi Project Sponsor @requiemmg
                      @requiemmg when it freezes at 48C then it’s no cooling issue. Try another SD card, maybe that’s the cause.
                      • BKeyportB Offline
                        BKeyport Module Developer
                        FYI, there’s plenty of fan PiHats to make it super easy to cool your Pi.
