    cannot install pm2
    46 Posts 2 Posters 12.6k Views 2 Watching
      mrlowndes
      @sdetweil could it not be working because npm WARN npm npm does not support Node.js v10.15.2?
        sdetweil @mrlowndes
        @mrlowndes hm I don’t know anything about how this website works. Just another user.
        Can u show me the ~/install.log?
          sdetweil @mrlowndes
          @mrlowndes no. Just a warning.
            mrlowndes
            @sdetweil ok how do I access the log? Also, I’ve been trying some other stuff since my last message
              mrlowndes
              install starting  - Wed Apr 29 16:55:58 PDT 2020
              installing on armv7l processor system
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              Updating packages ...
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] Fetched 15.0 kB in 1s (10.7 kB/s) Reading package lists...
              apt-get update  completed ok
              apt-get upgrade  started
              apt upgrade result =rc=0 Reading package lists...
              Building dependency tree...
              Reading state information...
              Calculating upgrade...
              The following packages have been kept back:
                binutils binutils-arm-linux-gnueabihf binutils-common libbinutils scratch3
              0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
              Installing helper tools ...
              build-essential is already the newest version (12.6).
              curl is already the newest version (7.64.0-4+deb10u1).
              git is already the newest version (1:2.20.1-2+deb10u3).
              unzip is already the newest version (6.0-23+deb10u1).
              wget is already the newest version (1.20.1-1.1).
              wget set to manually installed.
              Check current Node installation ...
              Node currently installed. Checking version number.
              Minimum Node version: v10.1.0
              Installed Node version: v10.15.2
              No Node.js upgrade necessary.
              Check current NPM installation ...
              NPM currently installed. Checking version number.
              Minimum npm version: V6.0.0
              Installed npm version: V5.8.0
              npm should be upgraded.
              Installing npm ...
              npm is already the newest version (5.8.0+ds6-4).
              npm set to manually installed.
              upgrading npm to latest
              /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
              /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
              + npm@6.14.4
              added 435 packages from 869 contributors in 77.435s
              npm installation Done! version=V6.14.4
              Cloning MagicMirror ...
              Cloning MagicMirror Done!
              Installing dependencies ...
              install starting  - Wed Apr 29 17:30:50 PDT 2020
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 https://deb.nodesource.com/node_10.x buster InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists...
              The following packages were automatically installed and are no longer required:
                gyp libc-ares2 libjs-inherits libjs-is-typedarray libssl-dev libuv1
                libuv1-dev node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex
                node-ansi-styles node-ansistyles node-aproba node-archy
                node-are-we-there-yet node-asn1 node-assert-plus node-asynckit
                node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
                node-boxen node-brace-expansion node-builtin-modules node-builtins
                node-cacache node-call-limit node-camelcase node-caseless node-chalk
                node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert
                node-color-name node-combined-stream node-concat-map node-concat-stream
                node-config-chain node-console-control-strings node-copy-concurrently
                node-core-util-is node-cross-spawn node-cyclist node-dashdash
                node-decamelize node-decompress-response node-deep-extend node-defaults
                node-delayed-stream node-delegates node-detect-indent node-detect-newline
                node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding
                node-end-of-stream node-errno node-escape-string-regexp node-execa
                node-extend node-extsprintf node-find-up node-flush-write-stream
                node-forever-agent node-form-data node-from2 node-fs-vacuum
                node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file
                node-get-stream node-getpass node-glob node-got node-graceful-fs
                node-har-schema node-har-validator node-has-flag node-has-symbol-support-x
                node-has-to-string-tag-x node-has-unicode node-hosted-git-info
                node-http-signature node-iconv-lite node-iferr node-import-lazy
                node-imurmurhash node-inflight node-inherits node-ini node-invert-kv
                node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
                node-is-retry-allowed node-is-stream node-is-typedarray node-isarray
                node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
                node-json-schema node-json-stable-stringify node-json-stringify-safe
                node-jsonify node-jsonparse node-jsonstream node-jsprim node-latest-version
                node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile
                node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn
                node-mimic-response node-minimatch node-minimist node-mississippi
                node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
                node-normalize-package-data node-npm-package-arg node-npm-run-path
                node-npmlog node-oauth-sign node-object-assign node-once node-opener
                node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit
                node-p-locate node-p-timeout node-package-json node-parallel-transform
                node-path-exists node-path-is-absolute node-path-is-inside
                node-performance-now node-prepend-http node-process-nextick-args
                node-promise-inflight node-promzard node-proto-list node-prr node-pump
                node-pumpify node-punycode node-qs node-qw node-rc node-read
                node-read-package-json node-readable-stream node-registry-auth-token
                node-registry-url node-request node-require-directory
                node-require-main-filename node-resolve-from node-retry node-rimraf
                node-run-queue node-safe-buffer node-semver node-semver-diff
                node-set-blocking node-sha node-shebang-command node-shebang-regex
                node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
                node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
                node-stream-each node-stream-iterate node-stream-shift node-string-decoder
                node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
                node-supports-color node-tar node-term-size node-text-table node-through
                node-through2 node-timed-out node-tough-cookie node-tunnel-agent
                node-tweetnacl node-typedarray node-uid-number node-unique-filename
                node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
                node-uuid node-validate-npm-package-license node-validate-npm-package-name
                node-verror node-wcwidth.js node-which node-which-module node-wide-align
                node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic
                node-xdg-basedir node-xtend node-y18n node-yallist node-yargs
                node-yargs-parser nodejs-doc
              Use 'sudo apt autoremove' to remove them.
              Installed Node version: v10.20.1
              Installed npm version: V6.14.4
              No npm upgrade necessary.
              It seems like MagicMirror is already installed.
              To prevent overwriting, the installer will be aborted.
              Please rename the ~/MagicMirror folder and try again.
              If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
              install starting  - Wed Apr 29 17:31:46 PDT 2020
              Hit:1 https://deb.nodesource.com/node_10.x buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists...
                sdetweil
                I am starting with another sd card… both users reporting problems had node 10.20.1…
                  mrlowndes
                  @sdetweil oh interesting. When I install Raspbian it I have 10.15, the only reason I upgraded it was because I was struggling with the manual install documentation and I thought that warning was more important than it is?
                    sdetweil @mrlowndes
                    @mrlowndes when I install raspian, I have never had node already installed… my script does all that
                      mrlowndes
                      @sdetweil oh maybe I’m mistaken then.
                        sdetweil @mrlowndes
                        @mrlowndes well, that doesn’t seem to be it
                        Dependencies installation Done!
                        configure the pm2 config file for MagicMirror
                        start MagicMirror via pm2 now
                        and started up
                        • 4 / 5
