    cannot install pm2
    46 Posts 2 Posters 16.1k Views 2 Watching
      mrlowndes
      @sdetweil still nothing:
      pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
      the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
      npm ERR! Unexpected end of JSON input while parsing near '...pes/node":"^12.7.5","'
      npm ERR!     /root/.npm/_logs/2020-04-29T21_00_10_606Z-debug.log
      bash: line 103: pm2: command not found
      bash: line 180: pm2: command not found
      bash: line 183: pm2: command not found
        @mrlowndes said in cannot install pm2:
        npm ERR! Unexpected end of JSON input while parsing near '…pes/node":"^12.7.
        u are getting weird failures…
        every time we have seen this, it is the SD card failing.
          mrlowndes
          hmm good question.
            mrlowndes
            @sdetweil should be fine its a SanDisk Ultra Plus 64GB U1 SDXC
              mrlowndes
              @sdetweil if it is the SD card, is it the kind of thing a deep format and reinstall of Raspbian will fix, or is the SD just terminally bad? Wen I reinstalled Raspbian the last time, I did just do a quick format on this card before flashing the image.
                sdetweil @mrlowndes
                @mrlowndes when the sd card starts to fail, it is toast
                  mrlowndes
                  @sdetweil bummer - it’s brand new out of the box. Just managed to scrounge another from my GoPro. Ill format that, reflash Raspbian and see how I go. I’ll just use your script first off, rather than doing a manual install. I’ll let you know how I get on, on here but it will take me a long time with all the updates that Raspbian does. Thanks so much for your help.
                    sdetweil @mrlowndes
                    @mrlowndes ok, will be around…
                      someone else just reported a similar failure on a pi 0.
                      so, I reflashed my sd card with buster and ran the installer without any issues on a pi 0w
                        mrlowndes
                        I ran your script and it didn’t finish - Unable to install dependencies! Also, this website has locked me out of singing into my account from my pi…
                          mrlowndes
                          @sdetweil could it not be working because npm WARN npm npm does not support Node.js v10.15.2?
                            sdetweil @mrlowndes
                            @mrlowndes hm I don’t know anything about how this website works. Just another user.
                            Can u show me the ~/install.log?
                              sdetweil @mrlowndes
                              @mrlowndes no. Just a warning.
                                mrlowndes
                                @sdetweil ok how do I access the log? Also, I’ve been trying some other stuff since my last message
                                  mrlowndes
                                  install starting  - Wed Apr 29 16:55:58 PDT 2020
                                  installing on armv7l processor system
                                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                  Updating packages ...
                                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] Fetched 15.0 kB in 1s (10.7 kB/s) Reading package lists...
                                  apt-get update  completed ok
                                  apt-get upgrade  started
                                  apt upgrade result =rc=0 Reading package lists...
                                  Building dependency tree...
                                  Reading state information...
                                  Calculating upgrade...
                                  The following packages have been kept back:
                                    binutils binutils-arm-linux-gnueabihf binutils-common libbinutils scratch3
                                  0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
                                  Installing helper tools ...
                                  build-essential is already the newest version (12.6).
                                  curl is already the newest version (7.64.0-4+deb10u1).
                                  git is already the newest version (1:2.20.1-2+deb10u3).
                                  unzip is already the newest version (6.0-23+deb10u1).
                                  wget is already the newest version (1.20.1-1.1).
                                  wget set to manually installed.
                                  Minimum Node version: v10.1.0
                                  Installed Node version: v10.15.2
                                  No Node.js upgrade necessary.
                                  Minimum npm version: V6.0.0
                                  Installed npm version: V5.8.0
                                  npm should be upgraded.
                                  Installing npm ...
                                  npm is already the newest version (5.8.0+ds6-4).
                                  npm set to manually installed.
                                  upgrading npm to latest
                                  /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                  /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                  + npm@6.14.4
                                  added 435 packages from 869 contributors in 77.435s
                                  npm installation Done! version=V6.14.4
                                  Cloning MagicMirror ...
                                  Cloning MagicMirror Done!
                                  Installing dependencies ...
                                  install starting  - Wed Apr 29 17:30:50 PDT 2020
                                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 https://deb.nodesource.com/node_10.x buster InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists...
                                    gyp libc-ares2 libjs-inherits libjs-is-typedarray libssl-dev libuv1
                                    libuv1-dev node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex
                                    node-ansi-styles node-ansistyles node-aproba node-archy
                                    node-are-we-there-yet node-asn1 node-assert-plus node-asynckit
                                    node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
                                    node-boxen node-brace-expansion node-builtin-modules node-builtins
                                    node-cacache node-call-limit node-camelcase node-caseless node-chalk
                                    node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert
                                    node-color-name node-combined-stream node-concat-map node-concat-stream
                                    node-config-chain node-console-control-strings node-copy-concurrently
                                    node-core-util-is node-cross-spawn node-cyclist node-dashdash
                                    node-decamelize node-decompress-response node-deep-extend node-defaults
                                    node-delayed-stream node-delegates node-detect-indent node-detect-newline
                                    node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding
                                    node-end-of-stream node-errno node-escape-string-regexp node-execa
                                    node-extend node-extsprintf node-find-up node-flush-write-stream
                                    node-forever-agent node-form-data node-from2 node-fs-vacuum
                                    node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file
                                    node-get-stream node-getpass node-glob node-got node-graceful-fs
                                    node-har-schema node-har-validator node-has-flag node-has-symbol-support-x
                                    node-has-to-string-tag-x node-has-unicode node-hosted-git-info
                                    node-http-signature node-iconv-lite node-iferr node-import-lazy
                                    node-imurmurhash node-inflight node-inherits node-ini node-invert-kv
                                    node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
                                    node-is-retry-allowed node-is-stream node-is-typedarray node-isarray
                                    node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
                                    node-json-schema node-json-stable-stringify node-json-stringify-safe
                                    node-jsonify node-jsonparse node-jsonstream node-jsprim node-latest-version
                                    node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile
                                    node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn
                                    node-mimic-response node-minimatch node-minimist node-mississippi
                                    node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
                                    node-normalize-package-data node-npm-package-arg node-npm-run-path
                                    node-npmlog node-oauth-sign node-object-assign node-once node-opener
                                    node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit
                                    node-p-locate node-p-timeout node-package-json node-parallel-transform
                                    node-path-exists node-path-is-absolute node-path-is-inside
                                    node-performance-now node-prepend-http node-process-nextick-args
                                    node-promise-inflight node-promzard node-proto-list node-prr node-pump
                                    node-pumpify node-punycode node-qs node-qw node-rc node-read
                                    node-read-package-json node-readable-stream node-registry-auth-token
                                    node-registry-url node-request node-require-directory
                                    node-require-main-filename node-resolve-from node-retry node-rimraf
                                    node-run-queue node-safe-buffer node-semver node-semver-diff
                                    node-set-blocking node-sha node-shebang-command node-shebang-regex
                                    node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
                                    node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
                                    node-stream-each node-stream-iterate node-stream-shift node-string-decoder
                                    node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
                                    node-supports-color node-tar node-term-size node-text-table node-through
                                    node-through2 node-timed-out node-tough-cookie node-tunnel-agent
                                    node-tweetnacl node-typedarray node-uid-number node-unique-filename
                                    node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
                                    node-uuid node-validate-npm-package-license node-validate-npm-package-name
                                    node-verror node-wcwidth.js node-which node-which-module node-wide-align
                                    node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic
                                    node-xdg-basedir node-xtend node-y18n node-yallist node-yargs
                                    node-yargs-parser nodejs-doc
                                  Use 'sudo apt autoremove' to remove them.
                                  Installed Node version: v10.20.1
                                  Installed npm version: V6.14.4
                                  No npm upgrade necessary.
                                  It seems like MagicMirror is already installed.
                                  To prevent overwriting, the installer will be aborted.
                                  Please rename the ~/MagicMirror folder and try again.
                                  If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
                                  install starting  - Wed Apr 29 17:31:46 PDT 2020
                                  Hit:1 https://deb.nodesource.com/node_10.x buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists...
                                    I am starting with another sd card… both users reporting problems had node 10.20.1…
                                      mrlowndes
                                      @sdetweil oh interesting. When I install Raspbian it I have 10.15, the only reason I upgraded it was because I was struggling with the manual install documentation and I thought that warning was more important than it is?
                                        sdetweil @mrlowndes
                                        @mrlowndes when I install raspian, I have never had node already installed… my script does all that
                                          mrlowndes
                                          @sdetweil oh maybe I’m mistaken then.
                                            sdetweil @mrlowndes
                                            @mrlowndes well, that doesn’t seem to be it
                                            Dependencies installation Done!
                                            configure the pm2 config file for MagicMirror
                                            start MagicMirror via pm2 now
                                            and started up
                                            • 2 / 3
