    cannot install pm2
    46 Posts 2 Posters 17.2k Views 2 Watching
      @sdetweil run the fixuppm2 script from my site
        mrlowndes
        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
        the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
        npm ERR! Unexpected end of JSON input while parsing near '...s":{"moment-timezone"'
        npm ERR!     /root/.npm/_logs/2020-04-29T20_09_52_853Z-debug.log
        bash: line 103: pm2: command not found
        bash: line 180: pm2: command not found
        bash: line 183: pm2: command not found
          sdetweil @mrlowndes
          @mrlowndes ok, lets do
          sudo npm purge -g pm2
            mrlowndes
            I don’t think that worked. Tried to paste code but got flagged as spam
              sdetweil @mrlowndes
              @mrlowndes
              try
              sudo npm uninstall -g pm2
                mrlowndes
                @sdetweil ok done. Now should I try bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)" again?
                  sdetweil @mrlowndes
                  @mrlowndes yes
                    mrlowndes
                    @sdetweil same result:
                    npm ERR!     /root/.npm/_logs/2020-04-29T20_19_40_905Z-debug.log
                      sdetweil @mrlowndes
                      @mrlowndes ok, time to get crazy , kill all npm stuff
                      /cd ~
                      sudo apt-get purge -y npm
                      sudo rm -rf .npm
                      sudo apt-get install -y npm
                      cd MagicMirror
                      rm -rf node_modules
                      npm install
                      then do the fixuppm2 script again
                        mrlowndes
                        @sdetweil still nothing:
                        npm ERR! Unexpected end of JSON input while parsing near '...pes/node":"^12.7.5","'
                        npm ERR!     /root/.npm/_logs/2020-04-29T21_00_10_606Z-debug.log
                          @mrlowndes said in cannot install pm2:
                          npm ERR! Unexpected end of JSON input while parsing near '…pes/node":"^12.7.
                          u are getting weird failures…
                          every time we have seen this, it is the SD card failing.
                            mrlowndes
                            hmm good question.
                              mrlowndes
                              @sdetweil should be fine its a SanDisk Ultra Plus 64GB U1 SDXC
                                mrlowndes
                                @sdetweil if it is the SD card, is it the kind of thing a deep format and reinstall of Raspbian will fix, or is the SD just terminally bad? Wen I reinstalled Raspbian the last time, I did just do a quick format on this card before flashing the image.
                                  sdetweil @mrlowndes
                                  @mrlowndes when the sd card starts to fail, it is toast
                                    mrlowndes
                                    @sdetweil bummer - it’s brand new out of the box. Just managed to scrounge another from my GoPro. Ill format that, reflash Raspbian and see how I go. I’ll just use your script first off, rather than doing a manual install. I’ll let you know how I get on, on here but it will take me a long time with all the updates that Raspbian does. Thanks so much for your help.
                                      sdetweil @mrlowndes
                                      @mrlowndes ok, will be around…
                                        someone else just reported a similar failure on a pi 0.
                                        so, I reflashed my sd card with buster and ran the installer without any issues on a pi 0w
                                          mrlowndes
                                          I ran your script and it didn’t finish - Unable to install dependencies! Also, this website has locked me out of singing into my account from my pi…
                                            mrlowndes
                                            @sdetweil could it not be working because npm WARN npm npm does not support Node.js v10.15.2?
                                            • 2 / 3
