    Calendar customization
    6 Posts 3 Posters 6.0k Views 2 Watching
    • D
      DelPhinDot
      I’ve just started to modify my mirror after getting it up n’ running.
      When i wanted to change the time format and remove the fade of the calendar i added the dateFormat and fade tags.
      But it doesn’t seem to do anything when i fire up the magic mirror…
      Anyone that’d like to help a noob in need, would be greatly appreciated!
      			module: 'calendar',
      			header: 'Schema',
      			position: 'bottom_center',
      				dateFormat: 'YYYY-MM-DD HH:mm',
      				fade: 'false',
      						symbol: 'calendar-check-o ',
      						url: 'https://www.schoolity.se/icalendar?id=c72fb38200f647302d97cc2384dc8ac247736f4078d3c3f01eeeabe5c56d2ff78d01961bda23a247'
      • O
        onetwankyfive
        this is done in the calendar.js file
        MagicMirror/modules/default/calendar/calendar.js
        • D
          DelPhinDot @onetwankyfive
          @onetwankyfive Ah i see, i tested to edit the calendar.js now instead. But it still doesn’t change the date so that i can see the exact time of the event in the calendar… Any tip?
          * global Module */
          /* Magic Mirror
           * Module: Calendar
           * MIT Licensed.
          Module.register("calendar",{
          	// Define module defaults
          	defaults: {
          		maximumEntries: 10, // Total Maximum Entries
          		maximumNumberOfDays: 365,
          		displaySymbol: true,
          		defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
          		displayRepeatingCountTitle: false,
          		defaultRepeatingCountTitle: '',
          		maxTitleLength: 25,
          		fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
          		animationSpeed: 2000,
          		fade: true,
          		urgency: 7,
          		timeFormat: "absolute",
          		fadePoint: 0.25, // Start on 1/4th of the list.
          				symbol: "calendar",
          			url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
          • D
            DelPhinDot
            I’m looking to make the events formatted like this “[eventname] [Month] [Day] [Time]” ex. “Physics Class Jan 11 08:11”
            • B
              broberg Project Sponsor
              Try setting the urgency var to 0
              • D
                DelPhinDot @broberg
                @broberg Thanks, i had changed the urgency to 0 after seeing what it did. Now i just had to solve the problem that all events within 6h would say “in 2 hours” instead of displaying the actual event time… After a bit of searching in the code i found this section: if (event.startDate - now < 6 * one_hour) and changed it to if (event.startDate - now < 1 * one_hour) , hence the calendar wold display the exact time not the time untill. (see code below)
                calendar.js
                			if (event.startDate >= new Date()) {
                				if (event.startDate - now < 2 * one_day) {
                					// This event is within the next 48 hours (2 days)
                					if (event.startDate - now < 1 * one_hour) {
                						// If event is within 1 hour, display 'in xxx' time format or moment.fromNow()
                						timeWrapper.innerHTML = moment(event.startDate, "x").fromNow();
                					} else {
                						// Otherwise just say 'Today/Tomorrow at such-n-such time'
                						timeWrapper.innerHTML = moment(event.startDate, "x").calendar();
