    MMM-RAIN-RADAR - Correct time
    13 Posts 4 Posters 4.3k Views 4 Watching
    • LordyL Offline
      Lordy
      Hello,
      I have a problem with correct time of “MMM-RAIN-RADAR”.
      The difference is currently 2 hours.
      I live in Berlin (+1 UTC) and summer time in Germany (+1 UTC).
      By config: “UTCtime: 1,” is the difference is currently 4 hours.
      I hope you can help me with this problem too?
      Here my Config:
      	module: "MMM-RAIN-RADAR",
      	disabled: false,
          	position: "middle_center",
      		header: "",
      		lat: 52.520007,
      		lon: 13.404954,
              	zoomLevel: 9,
              	mapType: 1, //0-Road Map 1-Satellite 2-Dark Map 3-OpenStreetMaps 4-Light Map
              	color: 3, //0-Original 1-Universal Blue 2-TITAN 3-The Weather Channel 5-NEXRAD Level-III 6-RAINBOW @ SELEX-SI
              	snow: 1,
              	smoothing: 1,
              	opacity: 88,
              	fastAnimation: 0,
              	coverage: 0,
              	darkTheme: 1,
              	UTCtime: 1,   //0=off  1=on, in der Anzeige (nochmal - 2 UTC)
              	legend: 1,
              	legendMin: 1, //set legend to 1 if you want legendMin to show
              	animate: 1,
              	updateOnWarning: 1, // 1: after updateInterval, weather warnings for your US states will be used to determine if module should be hidden. 0 module is perpertually displayed
              	updateInterval: 5 * 60 * 1000, // number of milliseconds. change 5 to 60 and it will update each 10 minutes
      lavolp3L bheplerB 2 Replies Last reply Reply Quote 0
      • lavolp3L Offline
        lavolp3 Module Developer @Lordy
        @Lordy I can’t follow completely.
        The rain radar covers a range of 2 hours.
        With UTCtime: 0 it should cover your current time -2 hours until your current time.
        Does the graphic show the time progression? When does it start, when does it stop?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        LordyL 1 Reply Last reply Reply Quote 0
        • LordyL Offline
          Lordy @lavolp3
          @lavolp3 said in MMM-RAIN-RADAR - Correct time:
          With “UTCtime: 1,” it starts -4 hours and “UTCtime: 0,” it starts -2 hours of the current time.The display time “UTCtime: 0,” ends with the current time. Shouldn’t the purpose of the “Rain Radar” be to warn me of future rain? Right now I feel like he’s only showing me the past weather. I hope I could answer your question. If not, I will be happy to assist you.
          Mit “UTCtime: 1,” fängt es -4 Stunden und “UTCtime: 0,” fängt es -2 Stunden der aktuellen Uhrzeit an. Die Anzeigezeit “UTCtime: 0,” hört mit der aktuellen Uhrzeit aus. Soll nicht der Sinn des “Rain-Radar” sein, mich vor zukünfigen Regen zu warnen. Momentan habe das Gefühl, er zeigt mir nur das vergangene Wetter an. Ich hoffe, ich könnte deine Frage beantworten. Wenn nicht, stehe ich Dir (euch) gerne zur Verfügung.
          • lavolp3L Offline
            @Lordy said in MMM-RAIN-RADAR - Correct time:
            THis is what it is intended to do.
            It only shows recent weather movement, not an outlook
            https://www.rainviewer.com/
            RainViewer shows you live precipitation map that shows how fast a storm has moved, how intense it’s been, and >what direction it’s moved in so far. Learn more.
            Have a look at my module MMM-Buienalarm if you live in Nordrhein Westfalen. It shows expected precipitation for the next 2 hours
            • LordyL Offline
              Lordy @lavolp3
              MMM-Buienalarm
              Thank you for your help. :thumbs_up_light_skin_tone: :slightly_smiling_face: So for me “MMM-Rain-Radar” is pointless. I lived in Berlin, “MMM-Buienalarm” doesn’t bring me anything, but I had already thought of that.
              Do you know good rain radars?
              Danke für deine Hilfe. Damit ist für mich “MMM-Rain-Radar” sinnlos. Da ich in Berlin lebte, bringt mir “MMM-Buienalarm” nix, aber daran hatte ich auch schon gedacht. Kennst Ihr gute Regenradare?
              • bheplerB Offline
                bhepler Module Developer @Lordy
                @Lordy - Please use the markdown features of the forum when publishing code or logs.
                • E Offline
                  Eisblume @Lordy
                  It would be nice if someone implemented the Rain-Radar from WetterOnline.de ;-)
                  • LordyL Offline
                    Lordy @Eisblume
                    @Eisblume
                    Right now, but I can’t find the iFrame address, can you help?
                    Bin gerade dabei, aber ich finde die iFrame- Adresse nicht, kannst dabei helfen? Für Berlin.
                    • LordyL Offline
                      Lordy @bhepler
                      @bhepler
                      I do not know what you mean?
                      Ich weiß nicht was du meinst?
                      • lavolp3L Offline
                        @bhepler
                        I have included it in your post.
                        The markdown feature gives copied code a “window” and proper formatting for better readability.
                        You can use the button “< />” above your input window for that.
                        • LordyL Offline
                          Lordy @lavolp3
                          @lavolp3
                              @bhepler
                          Do you mean so?
                          bheplerB 1 Reply Last reply Reply Quote 1
                          • bheplerB Offline
                            @Lordy - Yes, that’s it. Thank you.
                            • LordyL Offline
                              Lordy @bhepler
                              @bhepler
                              Okay, I will make future.
