    MMM-WiFiPassword module doesn't show up
    9 Posts 4 Posters 1.8k Views 4 Watching
      aurely89
      Hi everybody,
      I’ve installed MMM-WiFiPassword module on my MagicMirror and it simply doesn’t appear.
      I’ve tried to change the position and layout but nothing changed.
      Here is my module configuration array:
      module: 'WiFi Guest',
      position: "middle_center",
      	showNetwork: true,
      	network: "GUEST-Internet Home",
      	password: "xxxxxx",
      	qrSize: 125,
      	LayoutVertical: true,
      	showAuthType: false,
      Do you have any suggestions?
      Thank you!
      B StoffbeuteluweS 2 Replies Last reply Reply Quote 0
        bhepler Module Developer @aurely89
        @aurely89 - At this point, I would check the logs and see if they tell you anything. Either run the mirror with npm start dev to see the logs on your mirror, or connect to your mirror with a web browser and then hit F12 to bring up the developer console.
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @aurely89
          @aurely89 module name wrong ?
          right Name
          MMM-WiFiPassword
            aurely89 @bhepler
            @bhepler Thank you for your suggestion. Didn’t know such command. I could see that it was looking for a config file that didn’t exist since I’ve changed module name. Stupid me!
            By the way it is fixed now, thank you!
              aurely89 @Stoffbeuteluwe
              @Stoffbeuteluwe Exactly, that was the problem! Thank you!
                Glad you got it working! We’ve all made those simple-but-frustrating mistakes before. Don’t hesitate to ask for help when you’re stuck.
                  @aurely89 you can try to add
                  header:  “WiFi-Guest“,
                  to the module in your config
                    @Stoffbeuteluwe perfect suggestion, thank you!
                      Anthony Project Sponsor
                      Hello to all MM maniacs. I know this is an old topic but since I cannot find an answer to my problem I thought asking here as well. I recently installed MMM-WiFiPassword and while it reads My network and password it does not connect the phone to the network. I have tried to invert the colors and add some paddings but nothing. I have also tried 3 different scanners but still nothing. Only the last scanner after scanning the QR code and asked me to connect to network, it said something about android 10 lelease and above have some limitations for this. Does anyone else facing the same problem with this module? Thank you in advance.
