    Config
    6 Posts 3 Posters 1.0k Views 3 Watching
      sdmydbr
      Hi everyone, thanks for all those awesome modules and this cool magic mirror project, I have been building one for myself for about 2 months now. I’m no developer or have much knowledge regarding all these but I managed to do it. Today I don’t really know what went wrong but my config appears to be really jumbled up, after using admin interface module probably, my mirror still works fine with no config error but the config has totally change. I don’t know if I should be bothered with this…
      I will be posting a short sample of my changed config below…
      /* Magic Mirror Config Sample
      * MIT Licensed.
      var config = {
      	"port": 8080,
      	"language": "en",
      	"timeFormat": 24,
      	"units": "metric",
      	"modules": [
      			"module": "alert"
      			"module": "updatenotification",
      			"position": "top_bar"
      			"module": "clock",
      			"position": "top_left",
      			"config": {
      				"showWeek": true,
      				"showSunTimes": false,
      				"showMoonTimes": true,
      				"lat": 23.9062,
      				"lon": 91.4273,
      				"displayType": "digital",
      				"secondsColor": "#888888",
      				"analogPlacement": "right"
      			"module": "MMM-Volume",
      			"config": {
      				"usePresetScript": "ALSA",
      				"volumeOnStart": 50
      This is how the config looks like now… the mirror works fine but I’m having a hard time editing…
      • bheplerB Offline
        bhepler Module Developer @sdmydbr
        @sdmydbr - I’m not sure I understand what problem you’re having. You say your mirror works fine, but you’re having problems. You say your config.js is jacked up, but that looks like a valid config file.
        What are you trying to do and what behavior of the Pi is stopping you?
          sdmydbr @bhepler
          @bhepler well my previous config didn’t have quotations around the left hand side object. And now it has… I will post two configuration below…
          here is what my config use to look like…
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			     // false, default for all  NON-armv6l devices
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "US Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "YOUR_OPENWEATHER_API_KEY"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
          The above config is what I got when I installed magic mirror in the beginning…
          And now it has changed into
          * MIT Licensed.
          var config = {
          	"port": 8080,
          	"language": "en",
          	"timeFormat": 24,
          	"units": "metric",
          	"modules": [
          			"module": "alert"
          			"module": "clock",
          			"config": {
          				"showWeek": true,
          				"lat": 23.9062,
          				"lon": 91.4273,
          			"config": {
          				"volumeOnStart": 50
          			"module": "MMM-TelegramBot",
          			"config": {
          				"verbose": true,
          				"telegramAPIKey": "********",
          				"allowedUser": [
          					"sdmydbr"
          			"module": "MMM-MyCalendar",
          			"position": "bottom_bar",
          			"config": {
          				"calendars": [
          						"symbol": "calendar",
          						"url": "webcal://p55-caldav.icloud.com/published/2/MTYyNDUxMzU4NTMxNjI0NYC75Drqr02v7z3JKqrHR4_Vd4jSfdBaOYaOyJzk__IX"
          				"colored": true,
          				"maximunEntries": 5,
          				"fetchInterval": 30000
          			"disabled": true
          The difference between these two as u will notice is the double quote around the left side objects. I’m no programmer and I don’t know if this is the normal language but my config has changed… it works fine but the config is different now… all the modules have double quotes around them… as far as the mirror is concern it works fine. I just don’t understand why the change took place or if this is completely normal.
            sdetweil @sdmydbr
            @sdmydbr in javascript (the language the config is coded in, object and value names (things on the left of :
            do not need to be quoted.
              sdmydbr @sdetweil
              @sdetweil yes and I totally understand that but all the objects on the left of : has been automatically quoted… i didn’t do it… and my config arrangement has also automatically changed
                sdetweil @sdmydbr
                @sdmydbr did you use MMPM? (it probably accidetnally change the order and quoted)
                its doesn’t matter the order so much , position will decide,
                except if you cared about order in area
