    MagicMirror Pimatic (Home Automation) Dashboard
    35 Posts 10 Posters 37.9k Views 10 Watching
    • G Offline
      ganther
      Hello,
      I also installed your great module to observe the pimatic-sensor data on my MM.
      The normal systemsensor-temps are perfectly shown. But how can I get the values of my dht22-sensor because the class dhtsensor has no attributes. It delivers 2 values (Temp and humidity).
      Is there any solution?
      Thanks a lot.
      Sandy
      • Mr.SpontiM Offline
        Mr.Sponti
        @ganther said in MagicMirror Pimatic (Home Automation) Dashboard:
        dhtsensor
        Hi Sandy, how is your dht22-sensor connected? Is the sensor direct connected to the Rasperry GPIO pins and you use the plugin “dht-sensors”?
        What shows up for the sensor if you create a listing of “variables” from your pimatic menu?
        • G Offline
          ganther @Mr.Sponti
          @Mr.Sponti
          Thanks for your response.
          Yes, i use the dht-sensors plugin. It is directly connected to GPIO-Pin22
          Here is a Screenshot of a part of the device-config. Perhaps it‘s helpful.
          Thank you
          Sandy
          • G Offline
            ganther @ganther
            And the second menu area:
            • G Offline
              ganther @ganther
              Oh sorry, I didn‘t recognize the variables menue entry before oO🤦‍♂️
              It shows $dht22.temperature and .humidity
              I will try these ones in config.
              • G Offline
                ganther
                Yes, Temperatur is shown.
                But with 13 digits behind ‚.‘ just like 24.1234567890123
                Is there a way to cut after 1 or 2 digits behind ‚.‘?
                And a way to select another unit (% instead of degree) or do i have to move it to the notification board?
                Thanks again
                Sandy
                  Mr.Sponti
                  Rounding of the values is not a big issue as there is a method '.toFixed(2) ’ available. At the moment the unit specified in the config file is assigned to all values in the table. To implement the value rounding and a individual unit for every value I need to enhance the code. I will put it on my action list for the next version.
                  • G Offline
                    ganther @Mr.Sponti
                    @Mr.Sponti said in MagicMirror Pimatic (Home Automation) Dashboard:
                    Thank you very much!
                    • G Offline
                      ganther @ganther
                      One last thought:
                      If you add this feature in one of the next versions, it would be fantastic, if you could implement it on notification-board too (rounding and unit).
                      Then one module would be enough, it looks very nice and I would save one module-space.
                      Sandy
                        Mr.Sponti
                        Hi Sandy,
                        to display temperature and the humidity of your DST sensor in the Notification Board with rounded values and the right units should already possible. Try to use the following approach:
                        1. In pimatic create a VariableDevice with a string variable and assign a string including your temperature and humidity Variable.attributes of your DST sensor.
                          (e.q. “Livingroom temperature {round($DST_Temperature,1)} °C - humidity {round($DST_Humidity,1)} %”
                        2. Configure the new VariableDevice into the Notification Board of the MMM-Pimatic module
                        I didn’t test that, but it should work in that way.
                        • 3 / 4
