    MagicMirror Pimatic (Home Automation) Dashboard
    35 Posts 10 Posters 42.9k Views 10 Watching
    • Z
      Zinkeler @yawns
      @yawns
      Vielen Dank !!
      Genau das war das Problem, jetzt klappte es :-)
        Peter
        Who can help me with this?
        I am running MM on one RPI and Pimatic on another one.
        But I have no idea how to get the information of Pimatic on the MM screen.
        If somebody can tell me what to install where …
        Thanks in advance!
        Peter
          Mr.Sponti
          @Peter
          I’ve reworked my MMM-Pimatic modul but need now to adjust the description on gihub. The modul connects to a pimatic server to listen on device attribute changes and displays changes as notifications on the MagicMirror screen. Temperature values can be displayed in a separate table. As soon as I’ve completed the Readme, I will send you a message.
            Peter @Mr.Sponti
            @Mr.Sponti thanks!
            Would be great!
            Peter
              Mr.Sponti
              @Peter Here you can find the latest version of my MMM-Pimatic module. The README isn’t yet covering all features but should be sufficient for the installation and basic configuration of the module.
              Please feel free to contact me if you need help to get it running.
                Peter @Mr.Sponti
                @Mr.Sponti thanks!
                I will try it as soon as possible.
                I will let you know the results!
                Peter
                  Peter
                  pi@magicrpi:~/MagicMirror/modules/MMM-Pimatic $ npm install
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                  npm WARN modules No description
                  npm WARN modules No repository field.
                  npm WARN modules No README data
                  npm WARN modules No license field.
                  And I have no idea what to do (how to install) socket.io-client.
                  Peter
                    Mr.Sponti @Peter
                    @Peter , you can ignore these Warnings, but you need to install the socket.io-client modul:
                    cd  ~/MagicMirror/modules/MMM-Pimatic
                    npm install socket.io-client
                    • G
                      ganther
                      I also installed your great module to observe the pimatic-sensor data on my MM.
                      The normal systemsensor-temps are perfectly shown. But how can I get the values of my dht22-sensor because the class dhtsensor has no attributes. It delivers 2 values (Temp and humidity).
                      Is there any solution?
                      Thanks a lot.
                      Sandy
                        Mr.Sponti
                        @ganther said in MagicMirror Pimatic (Home Automation) Dashboard:
                        dhtsensor
                        Hi Sandy, how is your dht22-sensor connected? Is the sensor direct connected to the Rasperry GPIO pins and you use the plugin “dht-sensors”?
                        What shows up for the sensor if you create a listing of “variables” from your pimatic menu?
                        • G
                          ganther @Mr.Sponti
                          @Mr.Sponti
                          Thanks for your response.
                          Yes, i use the dht-sensors plugin. It is directly connected to GPIO-Pin22
                          Here is a Screenshot of a part of the device-config. Perhaps it‘s helpful.
                          Thank you
                          Sandy
                          • G
                            ganther @ganther
                            And the second menu area:
                            • G
                              ganther @ganther
                              Oh sorry, I didn‘t recognize the variables menue entry before oO🤦‍♂️
                              It shows $dht22.temperature and .humidity
                              I will try these ones in config.
                              • G
                                ganther
                                Yes, Temperatur is shown.
                                But with 13 digits behind ‚.‘ just like 24.1234567890123
                                Is there a way to cut after 1 or 2 digits behind ‚.‘?
                                And a way to select another unit (% instead of degree) or do i have to move it to the notification board?
                                Thanks again
                                Sandy
                                  Mr.Sponti
                                  Rounding of the values is not a big issue as there is a method '.toFixed(2) ’ available. At the moment the unit specified in the config file is assigned to all values in the table. To implement the value rounding and a individual unit for every value I need to enhance the code. I will put it on my action list for the next version.
                                  • G
                                    ganther @Mr.Sponti
                                    @Mr.Sponti said in MagicMirror Pimatic (Home Automation) Dashboard:
                                    Thank you very much!
                                    • G
                                      ganther @ganther
                                      One last thought:
                                      If you add this feature in one of the next versions, it would be fantastic, if you could implement it on notification-board too (rounding and unit).
                                      Then one module would be enough, it looks very nice and I would save one module-space.
                                      Sandy
                                        Mr.Sponti
                                        Hi Sandy,
                                        to display temperature and the humidity of your DST sensor in the Notification Board with rounded values and the right units should already possible. Try to use the following approach:
                                        1. In pimatic create a VariableDevice with a string variable and assign a string including your temperature and humidity Variable.attributes of your DST sensor.
                                          (e.q. “Livingroom temperature {round($DST_Temperature,1)} °C - humidity {round($DST_Humidity,1)} %”
                                        2. Configure the new VariableDevice into the Notification Board of the MMM-Pimatic module
                                        I didn’t test that, but it should work in that way.
                                        • G
                                          ganther @Mr.Sponti
                                          @Mr.Sponti
                                          Yes, Great! Both values are shown now rounded.
                                          How can I get the unit also be shown?
                                          In pimatic variables the units are declared and are shown.
                                          But not in notification board.
                                          Thank you!
                                            Mr.Sponti
                                            Sandy, I’ve tested the notification board with the following string varibale. The units of your measured values need to be part of the string defined in the field expression of your variable device.
                                            “Livingroom temperature {round($Temperaturen.Esszimmer,1)} °C - humidity {round($Temperaturen.Esszimmer,1)} %”
