    MagicMirror Pimatic (Home Automation) Dashboard
    35 Posts 10 Posters 42.9k Views 10 Watching
    • G
      ganther @Mr.Sponti
      @Mr.Sponti
      Thanks for your response.
      Yes, i use the dht-sensors plugin. It is directly connected to GPIO-Pin22
      Here is a Screenshot of a part of the device-config. Perhaps it‘s helpful.
      Thank you
      Sandy
      G 1 Reply Last reply
      • G
        ganther @ganther
        And the second menu area:
        • G
          ganther @ganther
          Oh sorry, I didn‘t recognize the variables menue entry before oO🤦‍♂️
          It shows $dht22.temperature and .humidity
          I will try these ones in config.
          • G
            ganther
            Yes, Temperatur is shown.
            But with 13 digits behind ‚.‘ just like 24.1234567890123
            Is there a way to cut after 1 or 2 digits behind ‚.‘?
            And a way to select another unit (% instead of degree) or do i have to move it to the notification board?
            Thanks again
            Sandy
              Mr.Sponti
              Rounding of the values is not a big issue as there is a method '.toFixed(2) ’ available. At the moment the unit specified in the config file is assigned to all values in the table. To implement the value rounding and a individual unit for every value I need to enhance the code. I will put it on my action list for the next version.
              • G
                ganther @Mr.Sponti
                @Mr.Sponti said in MagicMirror Pimatic (Home Automation) Dashboard:
                Thank you very much!
                • G
                  ganther @ganther
                  One last thought:
                  If you add this feature in one of the next versions, it would be fantastic, if you could implement it on notification-board too (rounding and unit).
                  Then one module would be enough, it looks very nice and I would save one module-space.
                  Sandy
                    Mr.Sponti
                    Hi Sandy,
                    to display temperature and the humidity of your DST sensor in the Notification Board with rounded values and the right units should already possible. Try to use the following approach:
                    1. In pimatic create a VariableDevice with a string variable and assign a string including your temperature and humidity Variable.attributes of your DST sensor.
                      (e.q. “Livingroom temperature {round($DST_Temperature,1)} °C - humidity {round($DST_Humidity,1)} %”
                    2. Configure the new VariableDevice into the Notification Board of the MMM-Pimatic module
                    I didn’t test that, but it should work in that way.
                    • G
                      ganther @Mr.Sponti
                      @Mr.Sponti
                      Yes, Great! Both values are shown now rounded.
                      How can I get the unit also be shown?
                      In pimatic variables the units are declared and are shown.
                      But not in notification board.
                      Thank you!
                        Mr.Sponti
                        Sandy, I’ve tested the notification board with the following string varibale. The units of your measured values need to be part of the string defined in the field expression of your variable device.
                        “Livingroom temperature {round($Temperaturen.Esszimmer,1)} °C - humidity {round($Temperaturen.Esszimmer,1)} %”
                        • G
                          ganther @Mr.Sponti
                          @Mr.Sponti
                          Something I‘m doing wrong.
                          If I add the unit in expression I always get parse errors.
                          The only thing that works is that way:
                          „{round($dht22.humidity,1)}%“
                          gives always parse errors
                          ¯_(ツ)_/¯
                            Mr.Sponti
                            Sandy, here is my definition for the VariableDevice:
                            Devices -> Add a new device… -> Class: VariableDevice --> Variables Add -->
                              Mike7400
                              In Pimatic i can see temp and humidity, but how to send these data to MMM-Pimaticfloorplan?
