    MagicMirror Pimatic (Home Automation) Dashboard
    35 Posts 10 Posters 42.4k Views 10 Watching
      Mr.Sponti
      @Peter Here you can find the latest version of my MMM-Pimatic module. The README isn’t yet covering all features but should be sufficient for the installation and basic configuration of the module.
      Please feel free to contact me if you need help to get it running.
        Peter @Mr.Sponti
        @Mr.Sponti thanks!
        I will try it as soon as possible.
        I will let you know the results!
        Peter
          Peter
          pi@magicrpi:~/MagicMirror/modules/MMM-Pimatic $ npm install
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
          npm WARN modules No description
          npm WARN modules No repository field.
          npm WARN modules No README data
          npm WARN modules No license field.
          And I have no idea what to do (how to install) socket.io-client.
          Peter
            Mr.Sponti @Peter
            @Peter , you can ignore these Warnings, but you need to install the socket.io-client modul:
            cd  ~/MagicMirror/modules/MMM-Pimatic
            npm install socket.io-client
            • G Offline
              ganther
              I also installed your great module to observe the pimatic-sensor data on my MM.
              The normal systemsensor-temps are perfectly shown. But how can I get the values of my dht22-sensor because the class dhtsensor has no attributes. It delivers 2 values (Temp and humidity).
              Is there any solution?
              Thanks a lot.
              Sandy
                Mr.Sponti
                @ganther said in MagicMirror Pimatic (Home Automation) Dashboard:
                dhtsensor
                Hi Sandy, how is your dht22-sensor connected? Is the sensor direct connected to the Rasperry GPIO pins and you use the plugin “dht-sensors”?
                What shows up for the sensor if you create a listing of “variables” from your pimatic menu?
                • G Offline
                  ganther @Mr.Sponti
                  @Mr.Sponti
                  Thanks for your response.
                  Yes, i use the dht-sensors plugin. It is directly connected to GPIO-Pin22
                  Here is a Screenshot of a part of the device-config. Perhaps it‘s helpful.
                  Thank you
                  Sandy
                  • G Offline
                    ganther @ganther
                    And the second menu area:
                    • G Offline
                      ganther @ganther
                      Oh sorry, I didn‘t recognize the variables menue entry before oO🤦‍♂️
                      It shows $dht22.temperature and .humidity
                      I will try these ones in config.
                      • G Offline
                        ganther
                        Yes, Temperatur is shown.
                        But with 13 digits behind ‚.‘ just like 24.1234567890123
                        Is there a way to cut after 1 or 2 digits behind ‚.‘?
                        And a way to select another unit (% instead of degree) or do i have to move it to the notification board?
                        Thanks again
                        Sandy
                          Mr.Sponti
                          Rounding of the values is not a big issue as there is a method '.toFixed(2) ’ available. At the moment the unit specified in the config file is assigned to all values in the table. To implement the value rounding and a individual unit for every value I need to enhance the code. I will put it on my action list for the next version.
                          • G Offline
                            ganther @Mr.Sponti
                            @Mr.Sponti said in MagicMirror Pimatic (Home Automation) Dashboard:
                            Thank you very much!
                            • G Offline
                              ganther @ganther
                              One last thought:
                              If you add this feature in one of the next versions, it would be fantastic, if you could implement it on notification-board too (rounding and unit).
                              Then one module would be enough, it looks very nice and I would save one module-space.
                              Sandy
                                Mr.Sponti
                                Hi Sandy,
                                to display temperature and the humidity of your DST sensor in the Notification Board with rounded values and the right units should already possible. Try to use the following approach:
                                1. In pimatic create a VariableDevice with a string variable and assign a string including your temperature and humidity Variable.attributes of your DST sensor.
                                  (e.q. “Livingroom temperature {round($DST_Temperature,1)} °C - humidity {round($DST_Humidity,1)} %”
                                2. Configure the new VariableDevice into the Notification Board of the MMM-Pimatic module
                                I didn’t test that, but it should work in that way.
                                • G Offline
                                  ganther @Mr.Sponti
                                  @Mr.Sponti
                                  Yes, Great! Both values are shown now rounded.
                                  How can I get the unit also be shown?
                                  In pimatic variables the units are declared and are shown.
                                  But not in notification board.
                                  Thank you!
                                    Mr.Sponti
                                    Sandy, I’ve tested the notification board with the following string varibale. The units of your measured values need to be part of the string defined in the field expression of your variable device.
                                    “Livingroom temperature {round($Temperaturen.Esszimmer,1)} °C - humidity {round($Temperaturen.Esszimmer,1)} %”
                                    • G Offline
                                      ganther @Mr.Sponti
                                      @Mr.Sponti
                                      Something I‘m doing wrong.
                                      If I add the unit in expression I always get parse errors.
                                      The only thing that works is that way:
                                      „{round($dht22.humidity,1)}%“
                                      gives always parse errors
                                      ¯_(ツ)_/¯
                                        Mr.Sponti
                                        Sandy, here is my definition for the VariableDevice:
                                        Devices -> Add a new device… -> Class: VariableDevice --> Variables Add -->
                                          Mike7400
                                          In Pimatic i can see temp and humidity, but how to send these data to MMM-Pimaticfloorplan?
