    MMM-NYC-Transit Module (Black Screen)
    20 Posts 2 Posters 5.7k Views 2 Watching
      JediJah @sdetweil
      @sdetweil pm2
      After adding disabled: true
      Got "Please create a config file " error
        sdetweil @JediJah
        @JediJah come on , the original instructions said
        disabled: true,
        just about any new line requires a comma at the end
          JediJah @sdetweil
          @sdetweil Yeah that was my bad… the mirror loads now without the module…
          :man_facepalming_medium-dark_skin_tone:
            sdetweil @JediJah
            @JediJah how do you start MM? using pm2 or manually
              JediJah @sdetweil
              @sdetweil I use pm2
                sdetweil @JediJah
                @JediJah ok, no stop mm using pm2
                fix the config.js,
                change the disabled to false
                disabled: false,
                go to the MagicMirror folder with a terminal window or ssh
                cd ~/MagicMirror
                npm start
                watch the messages
                  JediJah @sdetweil
                  @sdetweil said in MMM-NYC-Transit Module (Black Screen):
                  npm start
                  Looks like some files might be missing.
                  Here is a dump of messages:
                  [2020-05-22 20:49:37.148] [ERROR]  App threw an error during load
                  [2020-05-22 20:49:37.150] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                  Require stack:
                  - /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js
                      at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:8:24)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32)
                  [2020-05-22 20:49:37.155] [LOG]    Whoops! There was an uncaught exception...
                  [2020-05-22 20:49:37.158] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                  Require stack:
                      at Module.load (internal/modules/cjs/loader.js:645:32) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js',
                      '/home/pi/MagicMirror/js/app.js',
                      '/home/pi/MagicMirror/js/electron.js',
                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      undefined
                  [2020-05-22 20:49:37.173] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-05-22 20:49:37.175] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2020-05-22 20:49:37.336] [LOG]    Launching application.
                  I did clone the repo as required??
                    sdetweil @JediJah
                    @JediJah said in MMM-NYC-Transit Module (Black Screen):
                    Cannot find module ‘mta-realtime-subway-departures’
                    but it looks like you didn’t follow the module install instructions
                    1. clone this repo with the following command: git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                    2. install all the npm modules with either yarn install or npm install
                    to do 2, you need to change into the module folder
                    git clone ......
                    cd MMM-nyc-transit
                    npm install
                      JediJah @sdetweil
                      Looks like I ran npm install on modules dir.
                      pi@MagicMirror2:~/MagicMirror/modules $ git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                      Cloning into 'MMM-nyc-transit'...
                      remote: Enumerating objects: 67, done.
                      remote: Counting objects: 100% (67/67), done.
                      remote: Compressing objects: 100% (58/58), done.
                      remote: Total 176 (delta 34), reused 19 (delta 7), pack-reused 109
                      Receiving objects: 100% (176/176), 559.15 KiB | 649.00 KiB/s, done.
                      Resolving deltas: 100% (93/93), done.
                      pi@MagicMirror2:~/MagicMirror/modules $ npm install
                      I will correct as you noted.
                        JediJah
                        @sdetweil Thank you immensely for you help. It is running now.
