    MMM-NYC-Transit Module (Black Screen)
    20 Posts 2 Posters 6.9k Views 2 Watching
      sdetweil @JediJah
      @JediJah open the developers console, ctrl-shift-i on the mirror keyboard, select the tab labeled console, and put nyc in the filter field
      are there any errors shown, typically red text
        JediJah @sdetweil
        @sdetweil Thanks for the response. There are no errors shown.
        S J 2 Replies Last reply Reply Quote 0
          sdetweil @JediJah
          @JediJah ok, take the nyc out of the filter field… black screen means the UI died… so its gotta be there somewhere
          if u add
          disabled: true,
          to the module definition
          right after the module name
           module:'MMM-NYC-Transit',
           disabled: true,                                 // add this line
          does the black screen go away?
            JediJah @JediJah
            I realized I have since removed the config. I will re-add and check again.
              JediJah @sdetweil
              @sdetweil I added the module to config, disabled!
              The Mirror loads as normal.
              Something I find weird is even with the module disabled, its header is still shown.
              https://share.icloud.com/photos/09o6PENxnrT-_fTLvp8JN2mhw
                sdetweil @JediJah
                @JediJah it is not disabled according to the picture
                and the screen is not black
                if it were disabled, NOTHING about the module would show…
                same as if that entry was not in config.js at all
                  JediJah @sdetweil
                  @sdetweil I figured thats why I said it was weird.
                  This is what the module looked like in my config
                                module: 'MMM-nyc-transit',
                                disabled: "true",
                                position: "bottom_right",
                                header: "Next Train",
                                       apiKey: '9b76b0b756f7f9a76d4fe883075c00cf',
                                                  displayType: 'list',
                                                  mtaType: 'train',
                                                  stations: [
                                                          stationId: 95,
                                                          walkingTime: 5,
                                                          dir: {
        upTown: false,
        downTown: true
                                                          stationId: 95,
                                                          walkingTime: 5,
                                                          dir: {
        upTown: true,
        downTown: false
                                                  updateInterval: 300000
                  These are the steps I just tried…
                  recreated original circumstances that caused black screen (added Module to config) and yes the black screen still exist.
                  I assume that means there is issue with module config settings.
                  I tried to launch the Dev console, but it did not launch in same page as black mirror screen but a white page.
                  I will wait for your response before making changes to config.js file again.
                    sdetweil @JediJah
                    @JediJah said in MMM-NYC-Transit Module (Black Screen):
                              disabled: "true",
                    no, i said
                    disabled: true
                    no quotes
                    how do you start MM? using pm2 or manually
                      JediJah @sdetweil
                      @sdetweil Aww OK will adjust
                        JediJah @sdetweil
                        @sdetweil pm2
                        After adding disabled: true
                        Got "Please create a config file " error
                          sdetweil @JediJah
                          @JediJah come on , the original instructions said
                          disabled: true,
                          just about any new line requires a comma at the end
                            JediJah @sdetweil
                            @sdetweil Yeah that was my bad… the mirror loads now without the module…
                            :man_facepalming_medium-dark_skin_tone:
                              sdetweil @JediJah
                              @JediJah how do you start MM? using pm2 or manually
                                JediJah @sdetweil
                                @sdetweil I use pm2
                                  sdetweil @JediJah
                                  @JediJah ok, no stop mm using pm2
                                  fix the config.js,
                                  change the disabled to false
                                  disabled: false,
                                  go to the MagicMirror folder with a terminal window or ssh
                                  npm start
                                  watch the messages
                                    JediJah @sdetweil
                                    @sdetweil said in MMM-NYC-Transit Module (Black Screen):
                                    npm start
                                    Looks like some files might be missing.
                                    Here is a dump of messages:
                                    [2020-05-22 20:49:37.148] [ERROR]  App threw an error during load
                                    [2020-05-22 20:49:37.150] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                                    Require stack:
                                    - /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js
                                        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                        at Module.require (internal/modules/cjs/loader.js:685:19)
                                        at require (internal/modules/cjs/helpers.js:16:16)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:8:24)
                                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                        at Module.load (internal/modules/cjs/loader.js:645:32)
                                    [2020-05-22 20:49:37.155] [LOG]    Whoops! There was an uncaught exception...
                                    [2020-05-22 20:49:37.158] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                                    Require stack:
                                        at Module.load (internal/modules/cjs/loader.js:645:32) {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: [
                                        '/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js',
                                        '/home/pi/MagicMirror/js/app.js',
                                        '/home/pi/MagicMirror/js/electron.js',
                                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                        undefined
                                    [2020-05-22 20:49:37.173] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2020-05-22 20:49:37.175] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [2020-05-22 20:49:37.336] [LOG]    Launching application.
                                    I did clone the repo as required??
                                      sdetweil @JediJah
                                      Cannot find module ‘mta-realtime-subway-departures’
                                      but it looks like you didn’t follow the module install instructions
                                      1. clone this repo with the following command: git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                                      2. install all the npm modules with either yarn install or npm install
                                      to do 2, you need to change into the module folder
                                      git clone ......
                                      cd MMM-nyc-transit
                                      npm install
                                        JediJah @sdetweil
                                        Looks like I ran npm install on modules dir.
                                        pi@MagicMirror2:~/MagicMirror/modules $ git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                                        Cloning into 'MMM-nyc-transit'...
                                        remote: Enumerating objects: 67, done.
                                        remote: Counting objects: 100% (67/67), done.
                                        remote: Compressing objects: 100% (58/58), done.
                                        remote: Total 176 (delta 34), reused 19 (delta 7), pack-reused 109
                                        Receiving objects: 100% (176/176), 559.15 KiB | 649.00 KiB/s, done.
                                        Resolving deltas: 100% (93/93), done.
                                        pi@MagicMirror2:~/MagicMirror/modules $ npm install
                                        I will correct as you noted.
                                          JediJah
                                          @sdetweil Thank you immensely for you help. It is running now.
