    MMM-NYC-Transit Module (Black Screen)
    20 Posts 2 Posters 6.5k Views 2 Watching
      JediJah
      Hi All,
      I am getting a black screen after installing this module. Can I get some help reviewing what might have caused it. This is a new install on a RPI 3.
      I read this post thinking I may get insight into issue but to no avail. I even registered for a new API key and that wasn’t it.
      This is my current config.
      /* Magic Mirror Config JediJah
       * MIT Licensed.
      var config = {
      	address: "192.168.1.90",                                // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: [],                                       // Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			   module: "alert",
       		     module: "stocks",
       				 position: "top_bar",
       						stocks: "ACB,AMC,AMD,AAPL,BPFH,JBLU,SQ,TSLA,XXII", // stock symbols
       						updateInterval: 37000 // update interval in milliseconds
      		     module: "clock",
      			   position: "bottom_left"
      			   header: "Upcoming Events",
      			   position: "bottom_left",
      				 //maximumNumberOfDays: "15",
      				 maximumEntries: "8",
      				 colored: "true",
      	       coloredSymbolOnly: "true",
      				     // "MM Calendar"
      				         symbol: "jedi",
      					       color: "#0080FF",
      						     url: "webcal://p27-calendars.icloud.com/published/2/pUk76zgtLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL"
      					  // "Family Calendar"
      						     symbol: "users",
      						     color: "#FFFF33",
      						     url: "webcal://p27-calendars.icloud.com/published/2/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"
                module: "compliments",
      			    position: "upper_third",
      			  	compliments: {
      					anytime: [
      											"Hey there sexy!"
      				  morning: [
      												"It's a beautiful day \nIn Zamunda!",
      												"Enjoy your day!",
      												"How was your sleep?"
      					afternoon: [
      												"Hello!...",
      												"You look sexy!",
      												"Looking good today!"
      					evening: [
      												"Early to Bed, Early to Rise!",
      												"You look nice!",
      												"Hi, sexy!"
      					module: "currentweather",
      					position: "bottom_right",
      					locationID: "5110302",  												//ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      					appid: "54220318a8f6202d9b47dbccf5102fbe"
      					module: "weatherforecast",
      					header: "Weather Forecast",
      					locationID: "5110302",  											//ID from https://openweathermap.org/city
      					module: "newsfeed",
      					feeds: [
      									title: "The Verge",
      									url: "http://www.theverge.com/rss/full.xml"
      									title: "9to5mac",
      									url: "http://www.9to5mac.com/feed"
      					showSourceTitle: true,
      					showPublishDate: true
      	 				module: "updatenotification",
      					 module: 'MMM-nyc-transit',
      					 header: "Next Train",
      					 apiKey: '69c0a4199031a6dd60c00c3da86eae4c',
      					 displayType: 'list',
      					 mtaType: 'train',
      					 stations: [
      							 stationId: 95,
      							 walkingTime: 5,
      							 dir: {
      									 upTown: false,
      									 downTown: true
      								 stationId: 95,
      								 walkingTime: 5,
      								 dir: {
      										 upTown: true,
      										 downTown: false
      						 updateInterval: 300000
      Any help or insight will be most appreciated.
        sdetweil @JediJah
        @JediJah open the developers console, ctrl-shift-i on the mirror keyboard, select the tab labeled console, and put nyc in the filter field
        are there any errors shown, typically red text
          JediJah @sdetweil
          @sdetweil Thanks for the response. There are no errors shown.
          S J 2 Replies Last reply Reply Quote 0
            sdetweil @JediJah
            @JediJah ok, take the nyc out of the filter field… black screen means the UI died… so its gotta be there somewhere
            if u add
            disabled: true,
            to the module definition
            right after the module name
             module:'MMM-NYC-Transit',
             disabled: true,                                 // add this line
            does the black screen go away?
              JediJah @JediJah
              I realized I have since removed the config. I will re-add and check again.
                JediJah @sdetweil
                @sdetweil I added the module to config, disabled!
                The Mirror loads as normal.
                Something I find weird is even with the module disabled, its header is still shown.
                https://share.icloud.com/photos/09o6PENxnrT-_fTLvp8JN2mhw
                  sdetweil @JediJah
                  @JediJah it is not disabled according to the picture
                  and the screen is not black
                  if it were disabled, NOTHING about the module would show…
                  same as if that entry was not in config.js at all
                    JediJah @sdetweil
                    @sdetweil I figured thats why I said it was weird.
                    This is what the module looked like in my config
                                  disabled: "true",
                                         apiKey: '9b76b0b756f7f9a76d4fe883075c00cf',
                                                    mtaType: 'train',
                                                    stations: [
                                                            stationId: 95,
                                                            walkingTime: 5,
                                                            dir: {
        upTown: false,
        downTown: true
                                                            stationId: 95,
                                                            walkingTime: 5,
                                                            dir: {
        upTown: true,
        downTown: false
                    These are the steps I just tried…
                    recreated original circumstances that caused black screen (added Module to config) and yes the black screen still exist.
                    I assume that means there is issue with module config settings.
                    I tried to launch the Dev console, but it did not launch in same page as black mirror screen but a white page.
                    I will wait for your response before making changes to config.js file again.
                      sdetweil @JediJah
                      @JediJah said in MMM-NYC-Transit Module (Black Screen):
                                disabled: "true",
                      no, i said
                      disabled: true
                      no quotes
                      how do you start MM? using pm2 or manually
                        JediJah @sdetweil
                        @sdetweil Aww OK will adjust
                          JediJah @sdetweil
                          @sdetweil pm2
                          After adding disabled: true
                          Got "Please create a config file " error
                            sdetweil @JediJah
                            @JediJah come on , the original instructions said
                            disabled: true,
                            just about any new line requires a comma at the end
                              JediJah @sdetweil
                              @sdetweil Yeah that was my bad… the mirror loads now without the module…
                              :man_facepalming_medium-dark_skin_tone:
                                sdetweil @JediJah
                                @JediJah how do you start MM? using pm2 or manually
                                  JediJah @sdetweil
                                  @sdetweil I use pm2
                                    sdetweil @JediJah
                                    @JediJah ok, no stop mm using pm2
                                    fix the config.js,
                                    change the disabled to false
                                    disabled: false,
                                    go to the MagicMirror folder with a terminal window or ssh
                                    npm start
                                    watch the messages
                                      JediJah @sdetweil
                                      @sdetweil said in MMM-NYC-Transit Module (Black Screen):
                                      npm start
                                      Looks like some files might be missing.
                                      Here is a dump of messages:
                                      [2020-05-22 20:49:37.148] [ERROR]  App threw an error during load
                                      [2020-05-22 20:49:37.150] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                                      Require stack:
                                      - /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js
                                          at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                          at Module.require (internal/modules/cjs/loader.js:685:19)
                                          at require (internal/modules/cjs/helpers.js:16:16)
                                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:8:24)
                                          at Module._compile (internal/modules/cjs/loader.js:786:30)
                                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                          at Module.load (internal/modules/cjs/loader.js:645:32)
                                      [2020-05-22 20:49:37.155] [LOG]    Whoops! There was an uncaught exception...
                                      [2020-05-22 20:49:37.158] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                                      Require stack:
                                          at Module.load (internal/modules/cjs/loader.js:645:32) {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: [
                                          '/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js',
                                          '/home/pi/MagicMirror/js/app.js',
                                          '/home/pi/MagicMirror/js/electron.js',
                                          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                          undefined
                                      [2020-05-22 20:49:37.173] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      [2020-05-22 20:49:37.175] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      [2020-05-22 20:49:37.336] [LOG]    Launching application.
                                      I did clone the repo as required??
                                        sdetweil @JediJah
                                        Cannot find module ‘mta-realtime-subway-departures’
                                        but it looks like you didn’t follow the module install instructions
                                        1. clone this repo with the following command: git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                                        2. install all the npm modules with either yarn install or npm install
                                        to do 2, you need to change into the module folder
                                        git clone ......
                                        cd MMM-nyc-transit
                                        npm install
                                          JediJah @sdetweil
                                          Looks like I ran npm install on modules dir.
                                          pi@MagicMirror2:~/MagicMirror/modules $ git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                                          Cloning into 'MMM-nyc-transit'...
                                          remote: Enumerating objects: 67, done.
                                          remote: Counting objects: 100% (67/67), done.
                                          remote: Compressing objects: 100% (58/58), done.
                                          remote: Total 176 (delta 34), reused 19 (delta 7), pack-reused 109
                                          Receiving objects: 100% (176/176), 559.15 KiB | 649.00 KiB/s, done.
                                          Resolving deltas: 100% (93/93), done.
                                          pi@MagicMirror2:~/MagicMirror/modules $ npm install
                                          I will correct as you noted.
                                            JediJah
                                            @sdetweil Thank you immensely for you help. It is running now.
