    MMM-NYC-Transit Module (Black Screen)
    20 Posts 2 Posters 6.9k Views 2 Watching
      sdetweil @JediJah
      @JediJah ok, take the nyc out of the filter field… black screen means the UI died… so its gotta be there somewhere
      if u add
      disabled: true,
      to the module definition
      right after the module name
       module:'MMM-NYC-Transit',
       disabled: true,                                 // add this line
      does the black screen go away?
        JediJah @JediJah
        I realized I have since removed the config. I will re-add and check again.
          JediJah @sdetweil
          @sdetweil I added the module to config, disabled!
          The Mirror loads as normal.
          Something I find weird is even with the module disabled, its header is still shown.
          https://share.icloud.com/photos/09o6PENxnrT-_fTLvp8JN2mhw
            sdetweil @JediJah
            @JediJah it is not disabled according to the picture
            and the screen is not black
            if it were disabled, NOTHING about the module would show…
            same as if that entry was not in config.js at all
              JediJah @sdetweil
              @sdetweil I figured thats why I said it was weird.
              This is what the module looked like in my config
                            module: 'MMM-nyc-transit',
                            disabled: "true",
                            position: "bottom_right",
                            header: "Next Train",
                                   apiKey: '9b76b0b756f7f9a76d4fe883075c00cf',
                                              displayType: 'list',
                                              mtaType: 'train',
                                              stations: [
                                                      stationId: 95,
                                                      walkingTime: 5,
                                                      dir: {
                                                              upTown: false,
                                                              downTown: true
                                                      stationId: 95,
                                                      walkingTime: 5,
                                                      dir: {
                                                              upTown: true,
                                                              downTown: false
                                              updateInterval: 300000
              These are the steps I just tried…
              recreated original circumstances that caused black screen (added Module to config) and yes the black screen still exist.
              I assume that means there is issue with module config settings.
              I tried to launch the Dev console, but it did not launch in same page as black mirror screen but a white page.
              I will wait for your response before making changes to config.js file again.
                sdetweil @JediJah
                @JediJah said in MMM-NYC-Transit Module (Black Screen):
                          disabled: "true",
                no, i said
                disabled: true
                no quotes
                how do you start MM? using pm2 or manually
                  JediJah @sdetweil
                  @sdetweil Aww OK will adjust
                    JediJah @sdetweil
                    @sdetweil pm2
                    After adding disabled: true
                    Got "Please create a config file " error
                      sdetweil @JediJah
                      @JediJah come on , the original instructions said
                      disabled: true,
                      just about any new line requires a comma at the end
                        JediJah @sdetweil
                        @sdetweil Yeah that was my bad… the mirror loads now without the module…
                        :man_facepalming_medium-dark_skin_tone:
                          sdetweil @JediJah
                          @JediJah how do you start MM? using pm2 or manually
                            JediJah @sdetweil
                            @sdetweil I use pm2
                              sdetweil @JediJah
                              @JediJah ok, no stop mm using pm2
                              fix the config.js,
                              change the disabled to false
                              disabled: false,
                              go to the MagicMirror folder with a terminal window or ssh
                              npm start
                              watch the messages
                                JediJah @sdetweil
                                @sdetweil said in MMM-NYC-Transit Module (Black Screen):
                                npm start
                                Looks like some files might be missing.
                                Here is a dump of messages:
                                [2020-05-22 20:49:37.148] [ERROR]  App threw an error during load
                                [2020-05-22 20:49:37.150] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                                Require stack:
                                - /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js
                                    at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                    at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                    at Module.require (internal/modules/cjs/loader.js:685:19)
                                    at require (internal/modules/cjs/helpers.js:16:16)
                                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:8:24)
                                    at Module._compile (internal/modules/cjs/loader.js:786:30)
                                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                    at Module.load (internal/modules/cjs/loader.js:645:32)
                                [2020-05-22 20:49:37.155] [LOG]    Whoops! There was an uncaught exception...
                                [2020-05-22 20:49:37.158] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
                                Require stack:
                                    at Module.load (internal/modules/cjs/loader.js:645:32) {
                                  code: 'MODULE_NOT_FOUND',
                                  requireStack: [
                                    '/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js',
                                    '/home/pi/MagicMirror/js/app.js',
                                    '/home/pi/MagicMirror/js/electron.js',
                                    '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                    undefined
                                [2020-05-22 20:49:37.173] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [2020-05-22 20:49:37.175] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                [2020-05-22 20:49:37.336] [LOG]    Launching application.
                                I did clone the repo as required??
                                  sdetweil @JediJah
                                  Cannot find module ‘mta-realtime-subway-departures’
                                  but it looks like you didn’t follow the module install instructions
                                  1. clone this repo with the following command: git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                                  2. install all the npm modules with either yarn install or npm install
                                  to do 2, you need to change into the module folder
                                  git clone ......
                                  cd MMM-nyc-transit
                                  npm install
                                    JediJah @sdetweil
                                    Looks like I ran npm install on modules dir.
                                    pi@MagicMirror2:~/MagicMirror/modules $ git clone https://github.com/Elaniobro/MMM-nyc-transit.git
                                    Cloning into 'MMM-nyc-transit'...
                                    remote: Enumerating objects: 67, done.
                                    remote: Counting objects: 100% (67/67), done.
                                    remote: Compressing objects: 100% (58/58), done.
                                    remote: Total 176 (delta 34), reused 19 (delta 7), pack-reused 109
                                    Receiving objects: 100% (176/176), 559.15 KiB | 649.00 KiB/s, done.
                                    Resolving deltas: 100% (93/93), done.
                                    pi@MagicMirror2:~/MagicMirror/modules $ npm install
                                    I will correct as you noted.
                                      JediJah
                                      @sdetweil Thank you immensely for you help. It is running now.
