    Black screen: need help
    20 Posts 6 Posters 3.3k Views 6 Watching
    • ? Offline
      A Former User
      if i deprecied this module … sorry, unfortunately i have my reason :crying_face:
      Unfortunately, nothing is for granted … even for a developer (.even if we develop with pleasure and for free)
      I hope that on your side it will be better than me
        aamir6629
        pi@raspberrypi:~/MagicMirror $ npm start dev
        magicmirror@2.11.0 start /home/pi/MagicMirror
        DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
        [2020-06-05 08:24:47.909] [LOG] Starting MagicMirror: v2.11.0
        [2020-06-05 08:24:47.922] [LOG] Loading config ...
        [2020-06-05 08:24:47.931] [LOG] Loading module helpers ...
        [2020-06-05 08:24:47.934] [LOG] No helper found for module: alert.
        [2020-06-05 08:24:48.023] [LOG] Initializing new module helper ...
        [2020-06-05 08:24:48.024] [LOG] Module helper loaded: updatenotification
        [2020-06-05 08:24:48.025] [LOG] No helper found for module: clock.
        [2020-06-05 08:24:48.707] [LOG] Initializing new module helper ...
        [2020-06-05 08:24:48.708] [LOG] Module helper loaded: calendar
        [2020-06-05 08:24:48.709] [LOG] No helper found for module: compliments.
        [2020-06-05 08:24:48.710] [LOG] No helper found for module: currentweather.
        [2020-06-05 08:24:48.711] [LOG] No helper found for module: weatherforecast.
        [2020-06-05 08:24:48.718] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
        Require stack:
        /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
        /home/pi/MagicMirror/js/app.js
        /home/pi/MagicMirror/js/electron.js
        /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        [2020-06-05 08:24:48.720] [LOG] Loading module helpers ...
        [2020-06-05 08:24:48.721] [LOG] No helper found for module: alert.
        [2020-06-05 08:24:48.722] [LOG] Initializing new module helper ...
        [2020-06-05 08:24:48.722] [LOG] Module helper loaded: updatenotification
        [2020-06-05 08:24:48.723] [LOG] No helper found for module: clock.
        [2020-06-05 08:24:48.724] [LOG] Initializing new module helper ...
        [2020-06-05 08:24:48.725] [LOG] Module helper loaded: calendar
        [2020-06-05 08:24:48.725] [LOG] No helper found for module: compliments.
        [2020-06-05 08:24:48.726] [LOG] No helper found for module: currentweather.
        [2020-06-05 08:24:48.727] [LOG] No helper found for module: weatherforecast.
        [2020-06-05 08:24:48.730] [ERROR] App threw an error during load
        [2020-06-05 08:24:48.732] [ERROR] Error: Cannot find module '@bugsounet/lpcm16'
        Require stack:
        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
        at Module.require (internal/modules/cjs/loader.js:685:19)
        at require (internal/modules/cjs/helpers.js:16:16)
        at Object. (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
        at Module._compile (internal/modules/cjs/loader.js:786:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
        at Module.load (internal/modules/cjs/loader.js:645:32)
        [2020-06-05 08:24:48.734] [LOG] Whoops! There was an uncaught exception...
        [2020-06-05 08:24:48.735] [ERROR] Error: Cannot find module '@bugsounet/lpcm16'
        Require stack:
        at Module.load (internal/modules/cjs/loader.js:645:32) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
        '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
        '/home/pi/MagicMirror/js/app.js',
        '/home/pi/MagicMirror/js/electron.js',
        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
        undefined
        [2020-06-05 08:24:48.750] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-06-05 08:24:48.750] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-06-05 08:24:48.959] [LOG] Launching application.
        • Cr4z33C Offline
          Cr4z33 @Guest
          @Bugsounet don’t worry I don’t blame you mate only can you please tell me if there’s a way to revert before I did the module upgrade?
          Perhaps what @BKeyport said?
          If yes how exactly please? :grimacing_face:
          • BKeyportB Offline
            BKeyport Module Developer
            it’s a bit twisted, but there’s a way to figure out which module it is…
            Set up your config.js with every module commented out. Open comment is /* - close comment is */ I would set up one of the default modules (Alert) as the first module, and leave it alone, like this:
            			module: "alert",
            (insert remainder of modules here)
            Restart your Mirror. It should have no errors.
            Now, move the /* down to the next module and restart. Once it has error, you’ve found a troublesome module. Take it out.
            Keep going until you get the comments next to each other.
            Cr4z33C 2 Replies Last reply Reply Quote 0
            • ? Offline
              A Former User
              @Cr4z33 , @aamir6629 : I repeat again
              if i deprecied this module … sorry, unfortunately i have my reason 😢
              So : MMM-Hotword project is closed
              You can uninstall it and delete his config
              • Cr4z33C Offline
                Cr4z33 @BKeyport
                @BKeyport cheers I will definitely go that way! :thumbs_up_medium_skin_tone:
                Once I find out the ‘guilty’ module I will post back here.
                • Cr4z33C Offline
                  Cr4z33 @BKeyport
                  @BKeyport OK I’ve done it and it’s definitely because of MMM-Hotword.
                  Who can give me please a hand now to either (eventually) revert to a 2019 version or to fix this?
                  • ? Offline
                    A Former User
                    @Bugsounet said in Black screen: need help:
                    single result of MMM-Hotword deprecied
                    NO WAY, I HAVE CLOSE IT !
                    • Cr4z33C Offline
                      Cr4z33 @Guest
                      NO WAY I HAVE CLOSE IT !
                      I second that. :smirking_face:
                        sdetweil @Cr4z33
                        @Cr4z33 >Who can give me please a hand now to either (eventually) revert to a 2019 version or to fix this?
                        the Hotword and Assistant modules are no longer being used.
                        please delete the old modules from your system, and move to the new MMM-GoogleAssistant module
