    Black screen: need help
    20 Posts 6 Posters 3.6k Views 6 Watching
      A Former User
      single result of MMM-Hotword deprecied
      • cowboysdudeC Offline
        Funny things those modules…people make them, give them away and they have no further plans on doing anything to them.
        Some build them for their own use and share with the community expecting users to use it if they wish, improve it if they wish. No two mirrors are alike and sometimes you run into these issues.
        It may yet work but if someone wants to use it they may have to do some work on it and solve some issues to make them work.
        I’ve found that not everyone is a life long MagicMirror person… they come, they build they leave… it happens.
          A Former User
          if i deprecied this module … sorry, unfortunately i have my reason :crying_face:
          Unfortunately, nothing is for granted … even for a developer (.even if we develop with pleasure and for free)
          I hope that on your side it will be better than me
            aamir6629
            pi@raspberrypi:~/MagicMirror $ npm start dev
            magicmirror@2.11.0 start /home/pi/MagicMirror
            DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
            [2020-06-05 08:24:47.909] [LOG] Starting MagicMirror: v2.11.0
            [2020-06-05 08:24:47.922] [LOG] Loading config ...
            [2020-06-05 08:24:47.931] [LOG] Loading module helpers ...
            [2020-06-05 08:24:47.934] [LOG] No helper found for module: alert.
            [2020-06-05 08:24:48.023] [LOG] Initializing new module helper ...
            [2020-06-05 08:24:48.024] [LOG] Module helper loaded: updatenotification
            [2020-06-05 08:24:48.025] [LOG] No helper found for module: clock.
            [2020-06-05 08:24:48.707] [LOG] Initializing new module helper ...
            [2020-06-05 08:24:48.708] [LOG] Module helper loaded: calendar
            [2020-06-05 08:24:48.709] [LOG] No helper found for module: compliments.
            [2020-06-05 08:24:48.710] [LOG] No helper found for module: currentweather.
            [2020-06-05 08:24:48.711] [LOG] No helper found for module: weatherforecast.
            [2020-06-05 08:24:48.718] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
            Require stack:
            /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
            /home/pi/MagicMirror/js/app.js
            /home/pi/MagicMirror/js/electron.js
            /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            [2020-06-05 08:24:48.720] [LOG] Loading module helpers ...
            [2020-06-05 08:24:48.721] [LOG] No helper found for module: alert.
            [2020-06-05 08:24:48.722] [LOG] Initializing new module helper ...
            [2020-06-05 08:24:48.722] [LOG] Module helper loaded: updatenotification
            [2020-06-05 08:24:48.723] [LOG] No helper found for module: clock.
            [2020-06-05 08:24:48.724] [LOG] Initializing new module helper ...
            [2020-06-05 08:24:48.725] [LOG] Module helper loaded: calendar
            [2020-06-05 08:24:48.725] [LOG] No helper found for module: compliments.
            [2020-06-05 08:24:48.726] [LOG] No helper found for module: currentweather.
            [2020-06-05 08:24:48.727] [LOG] No helper found for module: weatherforecast.
            [2020-06-05 08:24:48.730] [ERROR] App threw an error during load
            [2020-06-05 08:24:48.732] [ERROR] Error: Cannot find module '@bugsounet/lpcm16'
            Require stack:
            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object. (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
            at Module._compile (internal/modules/cjs/loader.js:786:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
            at Module.load (internal/modules/cjs/loader.js:645:32)
            [2020-06-05 08:24:48.734] [LOG] Whoops! There was an uncaught exception...
            [2020-06-05 08:24:48.735] [ERROR] Error: Cannot find module '@bugsounet/lpcm16'
            Require stack:
            at Module.load (internal/modules/cjs/loader.js:645:32) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
            '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
            '/home/pi/MagicMirror/js/app.js',
            '/home/pi/MagicMirror/js/electron.js',
            '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
            undefined
            [2020-06-05 08:24:48.750] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2020-06-05 08:24:48.750] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [2020-06-05 08:24:48.959] [LOG] Launching application.
            • Cr4z33C Offline
              Cr4z33 @Guest
              @Bugsounet don’t worry I don’t blame you mate only can you please tell me if there’s a way to revert before I did the module upgrade?
              Perhaps what @BKeyport said?
              If yes how exactly please? :grimacing_face:
              • BKeyportB Offline
                BKeyport Module Developer
                it’s a bit twisted, but there’s a way to figure out which module it is…
                Set up your config.js with every module commented out. Open comment is /* - close comment is */ I would set up one of the default modules (Alert) as the first module, and leave it alone, like this:
                			module: "alert",
                (insert remainder of modules here)
                Restart your Mirror. It should have no errors.
                Now, move the /* down to the next module and restart. Once it has error, you’ve found a troublesome module. Take it out.
                Keep going until you get the comments next to each other.
                Cr4z33C 2 Replies Last reply Reply Quote 0
                  A Former User
                  @Cr4z33 , @aamir6629 : I repeat again
                  if i deprecied this module … sorry, unfortunately i have my reason 😢
                  So : MMM-Hotword project is closed
                  You can uninstall it and delete his config
                  • Cr4z33C Offline
                    Cr4z33 @BKeyport
                    @BKeyport cheers I will definitely go that way! :thumbs_up_medium_skin_tone:
                    Once I find out the ‘guilty’ module I will post back here.
                    • Cr4z33C Offline
                      Cr4z33 @BKeyport
                      @BKeyport OK I’ve done it and it’s definitely because of MMM-Hotword.
                      Who can give me please a hand now to either (eventually) revert to a 2019 version or to fix this?
                        A Former User
                        @Bugsounet said in Black screen: need help:
                        NO WAY, I HAVE CLOSE IT !
                        • Cr4z33C Offline
                          Cr4z33 @Guest
                          NO WAY I HAVE CLOSE IT !
                          I second that. :smirking_face:
                            sdetweil @Cr4z33
                            @Cr4z33 >Who can give me please a hand now to either (eventually) revert to a 2019 version or to fix this?
                            the Hotword and Assistant modules are no longer being used.
                            please delete the old modules from your system, and move to the new MMM-GoogleAssistant module
                            • Cr4z33C Offline
                              Cr4z33 @sdetweil
                              @sdetweil said in Black screen: need help:
                              please delete the old modules from your system move to the new MMM-GoogleAssistant module
                              My bad I didn’t surf the forums lately lol! :man_facepalming_medium_skin_tone:
                              Gonna check it NOW thanks!
                              • Cr4z33C Offline
                                Cr4z33 @sdetweil
                                @sdetweil I actually stopped configuring it because I have waaay too many custom voice commands that normal Google Assistant cannot execute.
                                  A Former User @Cr4z33
                                  @Cr4z33 :
                                  Why?
                                  Recipe is needed?
                                  GActions is needed?
                                  • Cr4z33C Offline
                                    Cr4z33 @Guest
                                    @Bugsounet I am not sure about your question.
                                    Anyway I am running custom voice commands (by Snowboy) to be able to ie. change stream (TV) in MMM-RTSPStream or CEC turn on/off the screen, etc.
                                    Can this be done? :)
                                    Can your new module voice control other MM modules?
                                      A Former User
                                      it’s include …
                                      Sample there
                                      pattern is “sentence to say” for execute commands
                                      Just Read wiki for more infos
                                      • Cr4z33C Offline
                                        Cr4z33 @Guest
                                        @Bugsounet OK thanks.
