    Black screen: need help
    20 Posts 6 Posters 4.5k Views 6 Watching
    • Cr4z33C
      Cr4z33 @Guest
      @Bugsounet don’t worry I don’t blame you mate only can you please tell me if there’s a way to revert before I did the module upgrade?
      Perhaps what @BKeyport said?
      If yes how exactly please? :grimacing_face:
      • BKeyportB
        BKeyport Module Developer
        it’s a bit twisted, but there’s a way to figure out which module it is…
        Set up your config.js with every module commented out. Open comment is /* - close comment is */ I would set up one of the default modules (Alert) as the first module, and leave it alone, like this:
        			module: "alert",
        (insert remainder of modules here)
        Restart your Mirror. It should have no errors.
        Now, move the /* down to the next module and restart. Once it has error, you’ve found a troublesome module. Take it out.
        Keep going until you get the comments next to each other.
        Cr4z33C 2 Replies Last reply Reply Quote 0
          A Former User
          @Cr4z33 , @aamir6629 : I repeat again
          if i deprecied this module … sorry, unfortunately i have my reason 😢
          So : MMM-Hotword project is closed
          You can uninstall it and delete his config
          • Cr4z33C
            Cr4z33 @BKeyport
            @BKeyport cheers I will definitely go that way! :thumbs_up_medium_skin_tone:
            Once I find out the ‘guilty’ module I will post back here.
            • Cr4z33C
              Cr4z33 @BKeyport
              @BKeyport OK I’ve done it and it’s definitely because of MMM-Hotword.
              Who can give me please a hand now to either (eventually) revert to a 2019 version or to fix this?
                A Former User
                @Bugsounet said in Black screen: need help:
                single result of MMM-Hotword deprecied
                if i deprecied this module … sorry, unfortunately i have my reason :crying_face:
                Unfortunately, nothing is for granted … even for a developer (.even if we develop with pleasure and for free)
                I hope that on your side it will be better than me
                NO WAY, I HAVE CLOSE IT !
                • Cr4z33C
                  Cr4z33 @Guest
                  NO WAY I HAVE CLOSE IT !
                  I second that. :smirking_face:
                    sdetweil @Cr4z33
                    @Cr4z33 >Who can give me please a hand now to either (eventually) revert to a 2019 version or to fix this?
                    the Hotword and Assistant modules are no longer being used.
                    please delete the old modules from your system, and move to the new MMM-GoogleAssistant module
                    • Cr4z33C
                      Cr4z33 @sdetweil
                      @sdetweil said in Black screen: need help:
                      please delete the old modules from your system move to the new MMM-GoogleAssistant module
                      My bad I didn’t surf the forums lately lol! :man_facepalming_medium_skin_tone:
                      Gonna check it NOW thanks!
                      • Cr4z33C
                        Cr4z33 @sdetweil
                        @sdetweil I actually stopped configuring it because I have waaay too many custom voice commands that normal Google Assistant cannot execute.
                          A Former User @Cr4z33
                          @Cr4z33 :
                          Why?
                          Recipe is needed?
                          GActions is needed?
                          • Cr4z33C
                            Cr4z33 @Guest
                            @Bugsounet I am not sure about your question.
                            Anyway I am running custom voice commands (by Snowboy) to be able to ie. change stream (TV) in MMM-RTSPStream or CEC turn on/off the screen, etc.
                            Can this be done? :)
                            Can your new module voice control other MM modules?
                              A Former User
                              it’s include …
                              Sample there
                              pattern is “sentence to say” for execute commands
                              Just Read wiki for more infos
                              • Cr4z33C
                                Cr4z33 @Guest
                                @Bugsounet OK thanks.
