    Due Monitor with Pi4
    8 Posts 3 Posters 1.0k Views 3 Watching
    • F Offline
      Fredi009
      Hello,
      my name is Frederic and currently i trying to set up a magic mirror with two screens.
      I read a bit throw the forum but can’t find a solution. So i hope you can help me with the problem. i have installed two session of magic mirror on my pi but every time i tried to start the mm.sh it program select display 1. How can i set the display output ?
        sdetweil @Fredi009
        @Fredi009 u have to add an entry to the second MM config.js
        config = {
          electronOptions:{x:????}
        etc rest of normal config
        ??? is the width of the 1st display (1920 or 3840 have worked for me)
        I am currently using , on my linux machine with 2 screens
        electronOptions: { x: 1920 }
        • F Offline
          Fredi009
          not directly… i solved it by myself…
          Now i have session 1 on the left screen and session 2 on the right.
          • F Offline
            Fredi009
            But now i have an other misstake. If i change something in the config of session 2. it already change in session 1, too. How i can solve these problem ?
              sdetweil @Fredi009
              @Fredi009 u must have TWO folders of MM…
              MagicMirrorLeft
              MagicMirrorRight
              two config files
              • F Offline
                Fredi009 @sdetweil
                Yes. I know.
                I have 2 folders. Magic mirror 2 and magic mirror
                • F Offline
                  Fredi009 @Fredi009
                  Yes. I know.
                  I have 2 folders. Magic mirror 2 and magic mirror. I’m at worh yet but in the evening i will try to change the mm.hh in the install folder. i think i forgot to change the direction there. in hime/pi/ i hav two mm.sh files with customized directions
                  • BKeyportB Offline
                    BKeyport Module Developer
                    FYI, it’s “Dual” Not “Due”. Might help you searching for answers in the future. 🙂
