    Mirror not starting after updating to MagicMirror² v2.12.0
    6 Posts 3 Posters 725 Views 3 Watching
      dmstansbury
      In case anyone else is facing this problem, here is the fix I found (using tips from some of the other threads, including from @sdetweil - thank you). This probably isn’t the ‘best’ or ‘right’ solution as I’m very new to all of this: I’m writing it down to help other similarly inexperienced folks.
      After running git pull && npm install in my MagicMirror folder, the mirror would no longer start, either on boot or when started from the terminal.
      I use some of the non-default modules (Boston MBTA and DarkSky weather). To make it work I had to also run npm install in the modules folder and in the config folder. After that is works fine.
      • S Away
        sdetweil @dmstansbury
        @dmstansbury and, if u had used my upgrade script, it would have done all that for you!
        Piranha1605P D 2 Replies Last reply Reply Quote 1
        • Piranha1605P Offline
          Piranha1605 @sdetweil
          As often as I have to put on my MM right now, your skips are part of life like eating. :cat_face_with_tears_of_joy: :cat_face_with_tears_of_joy: :cat_face_with_tears_of_joy:
            dmstansbury @sdetweil
            @sdetweil thanks! This looks great and very helpful. Is there a way to get that script onto this page? That’s where I saw the update instructions and tried my (noob) best from there
            • S Away
              @dmstansbury you just copy/paste the line from my readme, wherever you need it to go. I’d rather u not copy the instructions anywhere, so we only have one copy
              • S Away
                @dmstansbury as for THAT page. no
                my stuff is listed in the alternative installers section of the doc, but not ‘supported’ by the project. or, Mich won’t accept error reports or fix errors in my scripts
