    Upgrade Problem on Mac
    6 Posts 2 Posters 2.0k Views 2 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor
      Hi, @sdetweil i have used you install script but I have an error…
      patrickhahn@Mac-mini ~ % bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      apply: line 40: greadlink: command not found
      usage: dirname path
      the log will be /Users/patrickhahn/MagicMirror/installers/upgrade.log
      doing test run = false
      update log will be in /Users/patrickhahn/MagicMirror/installers/upgrade.log
      saving custom.css
      upgrading from version 2.11.0 to 2.12.0
      fetching latest revisions
      remote: Enumerating objects: 15023, done.
      remote: Counting objects: 100% (15023/15023), done.
      remote: Compressing objects: 100% (5704/5704), done.
      remote: Total 14778 (delta 9068), reused 14466 (delta 8767), pack-reused 0
      Receiving objects: 100% (14778/14778), 14.44 MiB | 5.67 MiB/s, done.
      Resolving deltas: 100% (9068/9068), completed with 182 local objects.
      From https://github.com/MichMich/MagicMirror
         447c0bf..018cb91  master     -> origin/master
       * [new tag]         v2.12.0    -> v2.12.0
       * [new tag]         V2.2.1     -> V2.2.1
       * [new tag]         v.2.1.3    -> v.2.1.3
       * [new tag]         v2.0.0     -> v2.0.0
       * [new tag]         v2.0.1     -> v2.0.1
       * [new tag]         v2.0.2     -> v2.0.2
       * [new tag]         v2.0.3     -> v2.0.3
       * [new tag]         v2.0.4     -> v2.0.4
       * [new tag]         v2.0.5     -> v2.0.5
       * [new tag]         v2.1.0     -> v2.1.0
       * [new tag]         v2.1.1     -> v2.1.1
       * [new tag]         v2.1.2     -> v2.1.2
       * [new tag]         v2.10.0    -> v2.10.0
       * [new tag]         v2.10.1    -> v2.10.1
       * [new tag]         v2.2.0     -> v2.2.0
       * [new tag]         v2.2.2     -> v2.2.2
       * [new tag]         v2.3.0     -> v2.3.0
       * [new tag]         v2.3.1     -> v2.3.1
       * [new tag]         v2.4.0     -> v2.4.0
       * [new tag]         v2.4.1     -> v2.4.1
       * [new tag]         v2.5.0     -> v2.5.0
       * [new tag]         v2.6.0     -> v2.6.0
       * [new tag]         v2.7.0     -> v2.7.0
       * [new tag]         v2.7.1     -> v2.7.1
       * [new tag]         v2.8.0     -> v2.8.0
       * [new tag]         v2.9.0     -> v2.9.0
      there are 5 local files that are different than the master repo
         installers/mm.sh
         js/socketclient.js
         package-lock.json
         package.json
         vendor/package-lock.json
      any *-lock.json files do not need to be saved
      do you want to save these files for later   (Y/n)?y
      updating MagicMirror runtime, please wait
      > electron@6.1.7 postinstall /Users/patrickhahn/MagicMirror/node_modules/electron
      > node install.js
      > magicmirror@2.12.0 install /Users/patrickhahn/MagicMirror
      > echo "Installing vendor files ...
      " && cd vendor && npm install --loglevel=error
      > fsevents@1.2.4 install /Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents
      > node install
        SOLINK_MODULE(target) Release/.node
        CXX(target) Release/obj.target/fse/fsevents.o
      In file included from ../fsevents.cc:6:
      In file included from ../../nan/nan.h:222:
      In file included from ../../nan/nan_converters.h:67:
      ../../nan/nan_converters_43_inl.h:22:1: warning: 'ToBoolean' is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
      X(Boolean)
      ../../nan/nan_converters_43_inl.h:18:12: note: expanded from macro 'X'
            val->To ## TYPE(isolate->GetCurrentContext())                            \
      <scratch space>:207:1: note: expanded from here
      ToBoolean
      /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:2663:3: note: 'ToBoolean' has been explicitly marked deprecated here
        V8_DEPRECATED("ToBoolean can never throw. Use Local version.",
      /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8config.h:328:29: note: expanded from macro 'V8_DEPRECATED'
        declarator __attribute__((deprecated(message)))
      ../../nan/nan_converters_43_inl.h:40:1: warning: 'BooleanValue' is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
      X(bool, Boolean)
      ../../nan/nan_converters_43_inl.h:37:15: note: expanded from macro 'X'
        return val->NAME ## Value(isolate->GetCurrentContext());                     \
      <scratch space>:214:1: note: expanded from here
      BooleanValue
      /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:2701:3: note: 'BooleanValue' has been explicitly marked deprecated here
        V8_DEPRECATED("BooleanValue can never throw. Use Isolate version.",
      In file included from ../../nan/nan.h:223:
      In file included from ../../nan/nan_new.h:189:
      ../../nan/nan_implementation_12_inl.h:356:37: error: too few arguments to function call, expected 2, have 1
        return v8::StringObject::New(value).As<v8::StringObject>();
      /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:5531:3: note: 'New' declared here
        static Local<Value> New(Isolate* isolate, Local<String> value);
      In file included from ../../nan/nan.h:2722:
      ../../nan/nan_object_wrap.h:24:25: error: no member named 'IsNearDeath' in 'Nan::Persistent<v8::Object, v8::NonCopyablePersistentTraits<v8::Object> >'
          assert(persistent().IsNearDeath());
      /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/assert.h:93:25: note: expanded from macro 'assert'
          (__builtin_expect(!(e), 0) ? __assert_rtn(__func__, __FILE__, __LINE__, #e) : (void)0)
      ../../nan/nan_object_wrap.h:127:26: error: no member named 'IsNearDeath' in 'Nan::Persistent<v8::Object, v8::NonCopyablePersistentTraits<v8::Object> >'
          assert(wrap->handle_.IsNearDeath());
      ../fsevents.cc:50:32: error: no template named 'Handle' in namespace 'v8'
          static void Initialize(v8::Handle<v8::Object> exports);
      ../fsevents.cc:63:6: warning: field 'async_resource' will be initialized after field 'lockStarted' [-Wreorder]
         : async_resource("fsevents:FSEvents"), lockStarted(false) {
      In file included from ../fsevents.cc:82:
      ../src/constants.cc:89:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagNone").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagNone));
      /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:3498:3: note: 'Set' has been explicitly marked deprecated here
        V8_DEPRECATED("Use maybe version",
      ../src/constants.cc:90:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagMustScanSubDirs").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagMustScanSubDirs));
      ../src/constants.cc:91:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagUserDropped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagUserDropped));
      ../src/constants.cc:92:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagKernelDropped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagKernelDropped));
      ../src/constants.cc:93:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagEventIdsWrapped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagEventIdsWrapped));
      ../src/constants.cc:94:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagHistoryDone").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagHistoryDone));
      ../src/constants.cc:95:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagRootChanged").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagRootChanged));
      ../src/constants.cc:96:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagMount").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagMount));
      ../src/constants.cc:97:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagUnmount").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagUnmount));
      ../src/constants.cc:98:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemCreated").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemCreated));
      ../src/constants.cc:99:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemRemoved").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemRemoved));
      ../src/constants.cc:100:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemInodeMetaMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemInodeMetaMod));
      ../src/constants.cc:101:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemRenamed").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemRenamed));
      ../src/constants.cc:102:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemModified").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemModified));
      ../src/constants.cc:103:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemFinderInfoMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemFinderInfoMod));
      ../src/constants.cc:104:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemChangeOwner").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemChangeOwner));
      ../src/constants.cc:105:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemXattrMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemXattrMod));
      ../src/constants.cc:106:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsFile").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsFile));
      ../src/constants.cc:107:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsDir").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsDir));
      ../src/constants.cc:108:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
        object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsSymlink").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsSymlink));
      ../fsevents.cc:85:16: error: variable has incomplete type 'void'
      void FSEvents::Initialize(v8::Handle<v8::Object> exports) {
      ../fsevents.cc:85:31: error: no member named 'Handle' in namespace 'v8'
      ../fsevents.cc:85:48: error: expected '(' for function-style cast or type construction
      ../fsevents.cc:85:50: error: use of undeclared identifier 'exports'
      ../fsevents.cc:85:58: error: expected ';' after top level declarator
      23 warnings and 9 errors generated.
      make: *** [Release/obj.target/fse/fsevents.o] Error 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Darwin 19.5.0
      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64/fse.node" "--module_name=fse" "--module_path=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64" "--napi_version=5" "--node_abi_napi=napi"
      gyp ERR! cwd /Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents
      gyp ERR! node -v v12.16.3
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64/fse.node --module_name=fse --module_path=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64 --napi_version=5 --node_abi_napi=napi' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
      node-pre-gyp ERR! System Darwin 19.5.0
      node-pre-gyp ERR! command "/usr/local/bin/node" "/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/node_modules/node-pre-gyp/bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents
      node-pre-gyp ERR! node -v v12.16.3
      node-pre-gyp ERR! node-pre-gyp -v v0.10.0
      node-pre-gyp ERR! not ok
      added 62 packages from 37 contributors, removed 3 packages, updated 17 packages and audited 150 packages in 40.858s
      found 8 vulnerabilities (7 low, 1 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.12.0 postinstall /Users/patrickhahn/MagicMirror
      > npm run install-fonts && echo "MagicMirror installation finished successfully!
      > magicmirror@2.12.0 install-fonts /Users/patrickhahn/MagicMirror
      > echo "Installing fonts ...
      " && cd fonts && npm install --loglevel=error
      updated 1 package and audited 1 package in 0.476s
      found 0 vulnerabilities
      do you have an idea ? thanks in advance
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe I do not know. I didn’t have this error on my Mac Catalina upgrade.
        I am in hospital for a little while longer and can’t debug much w my phone
          @Stoffbeuteluwe looks like fsevents 1.2.4 is old and we need 2.x
          but mm doesn’t use it directly.
          so u might be able to help
          from a terminal window ( not exactly sure of the syntax)
          cd ~/MagicMirror
          find node_modules -n package.json | grep fsevents
          then u can try
          npm install fsevents
          npm install
            @Stoffbeuteluwe I rechecked my upgrade build, (on catalina) and it didn’t try to recompile vendor/fsevents.
            can u try
            cd ~/MagicMirror/vendor
            rm -rf node_modules
            rm package-lock.json
            npm install
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @sdetweil
              @sdetweil thank you Sam I have upgraded successfully
                @Stoffbeuteluwe awesome. thanks for the update
