    Weather modules
    22 Posts 9 Posters 7.5k Views 9 Watching
    • C Offline
      ColinT @BKeyport
      @BKeyport Dark sky is now apple only ☹️
      • Feedy88F Offline
        Feedy88 @BKeyport
        @BKeyport in my opinion it clearly is. Let’s see if some new modules pop up (openweather onecall API, climacell…)
        • BKeyportB Offline
          BKeyport Module Developer @ColinT
          @ColinT Not quite yet. They’re going apple only in a year or so.
            My darksky key is still working. My BMW series of weather modules uses darksky(still) and OpenWeather and Climacell keys. There’s also a Climacell Hourly. However, WeatherOrNot requires no api key at all.
            • W Offline
              wheresmygravy
              I just found MMM-WeatherOrNot after trying several others. I like it because you can set a background behind the module. My MagicMirror is not a mirror at all and uses random images behind all of my modules, so the contrast in needed.
              Is there a simple way to increase the size of the fonts? They are a little hard to read for my 81-yr old mother in law.
              Thank you.
                Mykle1 Project Sponsor Module Developer @wheresmygravy
                @wheresmygravy said in Weather modules:
                Unfortunately, font size is not an option with this module.
                Feedy88F 1 Reply Last reply Reply Quote 0
                • Feedy88F Offline
                  Feedy88 @Mykle1
                  @Mykle1 Woulnd’t it be possible via a custom css?
                    Mykle1 Project Sponsor Module Developer @Feedy88
                    @Feedy88 said in Weather modules:
                    It would not. The module is inside of an iFrame and only those options available at the source can be modified. Font Size is not one of those options
                    • Feedy88F Offline
                      Feedy88 @Mykle1
                      @Mykle1 Understood. Guess that is the part making it responsive as you change the size?
                        audun
                        This weather module works great.
                        https://github.com/martinkooij/MMM-MyWeather
                        It’s the same as the one from jclarke0000, but this uses weatherbit.io api instead.
                        • 2 / 3
