    [MMM-RTSPStream] Cannot get vlc to work
    7 Posts 4 Posters 1.9k Views 4 Watching
    • R
      requiemmg
      I have a cheap IP camera.
      When I use my stream URL on my windows machine with VLC, it plays alright.
      When I use omxplayer, I get the video stream rotated by 90 degrees (which I can fix), but totally out of the window, somewhere on the screen.
      When I use VLC or ffmpeg, I only get a blank screen. Any idea about this? I’d like to use VLC.
      I only use one stream at the moment.
      Config is as follows:
                  module: "MMM-RTSPStream",
                  position: "upper_third",
                      autoStart: true,
                      rotateStreams: false,
                      rotateStreamTimeout: 10,
                      moduleWidth: 640,
                      moduleHeight: 480,
                      localPlayer: 'vlc',
                      showSnapWhenPaused: false,
                      remoteSnaps: false,
                      stream1: {
                          url: 'http://user:pass@IP:Port/videostream.cgi?usr=username&pwd=password',
                          frameRate: '10',
                          width: 640,
                          height: 480,
                          rotateDegree: 90,
      • BKeyportB
        BKeyport Module Developer
        I’ve never gotten VLC to work properly.
        Matter of fact, I’ve stopped using RTSPStream in favor of a custom module to open up a hole the screen for the camera, and manually running OMXPlayer so I can control it better because rotation never quite worked right.
        • Cr4z33C
          Cr4z33
          I moved from a RPI 4 to an Intel NUC and I actually got MMM-RTSPStream (almost) working.
          The issue is that it does completely ignore my window size & position settings.
          If it is a 1080i/1080p it gets displayed almost at 100% of screen while if it is at 576p it gets displayed on top left occupying 1/4 of the screen…
          I am in desperate need to fix this module because it basically was the reason to build my smart mirror…
          • BKeyportB
            Check out https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/512?_=1595809229819
            This is how to run OMX on top of the mirror, it’s super easy - around that post is all sorts of tricks on how to do it.
            My use is on my rotated screen, in the upper right corner, 415 x 750 Window (The coordinates will always be landscape)
            omxplayer --avdict rtsp_transport:tcp --live --orientation 90 --win "1500 320 1915 1070" rtsp://user:pass@frontcam/h264Preview_01_sub
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @BKeyport
              @BKeyport we cannot use omxplayer on hardwares (Intel NUC in my case) other than Raspberry. ;)
              • Cr4z33C
                Cr4z33
                For your information MMM-FreeboxTV (with some little edits) does everything MMM-RTSPStream did with the difference that it keeps being developed and it works fine with VLC! 😁
                  A Former User
                  lol, If my module can help :)
                  At start, it’s for french user for wathing TV … now it’s for every one simply editing or create your own stream file ;)
                  It’s works ONLY with VLC
