    Error - EADDRINUSE
    6 Posts 2 Posters 3.0k Views 2 Watching
    • I
      Ice-cream
      Hi everyone, I’m new to MM and coding.
      Situation - when I ran , I received an odd note in my terminal (copied the below from Google).
      Error: listen EADDRINUSE: address already in use :::8080
          at Server.setupListenHandle [as _listen2] (net.js:1258:14)
          at listenInCluster (net.js:1306:12)
          at Server.listen (net.js:1394:7)
      I found some instructions online and then KILLED something in the terminal (again copied from Google):
      node 2464 murari 21u IPv6 4392639 0t0 TCP *:http-alt
      So I killed MY PID which was a different number and I’ve sort of fucked up my MM.
      When I run the MM, I receive this error now - could someone please help? Thank you Xx
      code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '[deleted]',
        port: 8080
      [2020-07-26 09:30:22.750] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-07-26 09:30:22.750] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-07-26 09:30:22.780] [LOG]    Launching application.
      ^C
        sdetweil @Ice-cream
        @Ice-cream
        if u reboot, does mm start?
        how did u install? the automated script? if so, did u say yes to “use pm2 to autostart”?
        maybe do
        pm2 status
        otherwise some other app is using the same port as mm wants to use.
        edit config.js, and change
        port:8080,
        to
        port:8090,
        • I
          Ice-cream
          Sorry, that did not work - error I receive.
          code: ‘EADDRINUSE’,
          errno: ‘EADDRINUSE’,
          syscall: ‘listen’,
          address: ‘[delete]’,
          port: 8090
          Yes MM auto-starts on reboot > yes to automated script > I followed these steps: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror.
          The current error when I run
          pm2 restart mm
          Use --update-env to update environment variables
          [PM2] Applying action restartProcessId on app [mm](ids: 0,1)
          [PM2] mm â
          [PM2] mm â
          ââââââ¬âââââââââââââââââââââ¬âââââââââââ¬âââââââ¬ââââââââââââ¬âââââââââââ¬âââââââââââ
          â id â name â mode â ⺠â status â cpu â memory â
          ââââââ¼âââââââââââââââââââââ¼âââââââââââ¼âââââââ¼ââââââââââââ¼âââââââââââ¼âââââââââââ¤
          â 0 â mm â fork â 0 â errored â 0% â 0b â
          â 1 â mm â fork â 1 â online â 0% â 1.8mb â
          ââââââ´âââââââââââââââââââââ´âââââââââââ´âââââââ´ââââââââââââ´âââââââââââ´âââââââââââ
          I’ve also run
          pm2 logs mm
          pi@raspberrypi:~ $ pm2 logs mm
          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
          /home/pi/.pm2/logs/mm-error.log last 15 lines:
          0|mm | npm ERR! Failed at the magicmirror@2.12.0 start script.
          0|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          0|mm |
          0|mm | npm ERR! A complete log of this run can be found in:
          0|mm | npm ERR! /home/pi/.npm/_logs/2020-07-26T00_13_44_413Z-debug.log
          0|mm | npm ERR! code ELIFECYCLE
          0|mm | npm ERR! errno 1
          0|mm | npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          0|mm | npm ERR! Exit status 1
          0|mm | npm ERR!
          0|mm |
          0|mm | npm ERR! /home/pi/.npm/_logs/2020-07-26T00_36_04_600Z-debug.log
          I’ve just checked and I do not have a doc electron.js from this source - ./node_modules/.bin/electron js/electron.js.
          I remember that all I did was type kill in the terminal and killed a number - what mess have I caused!!! I’m so sorry :(
          The instructions I followed - I stopped after I entered kill and the number (I think mine began with a 5 or 9)
            sdetweil @Ice-cream
            @Ice-cream can u show me the top of config.js and show me how u start magic mirror
            • I
              Ice-cream @sdetweil
              config = {
              	address: "localhost", 	// Address to listen on, can be:
              	port: 8090,
              	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                sdetweil @Ice-cream
                @Ice-cream ok, all. makes no sense do
                pm2 stop 0
                reboot
                now, system should reboot, and mm should not restart.
                then do
                cd ~/MagicMirror
                npm start >somefile 2>&1
                if mm does not start press ctr-c to stop the npm start
                edit the somefile
