    • Following 1
    • Topics 2
    • Posts 11
    I Offline
    2. Ice-cream
    Ice-cream
    @Ice-cream
    Ice-cream Unfollow Follow
    • RE: Error - EADDRINUSE
      config = {
      	address: "localhost", 	// Address to listen on, can be:
      							// - "localhost", "127.0.0.1", "::1" to listen on loopback interface
      							// - another specific IPv4/6 to listen on a specific interface
      							// - "0.0.0.0", "::" to listen on any interface
      							// Default, when address config is left out or empty, is "localhost"
      	port: 8090,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      					// you must set the sub path here. basePath must end with a /
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      															// or add a specific IPv4 of 192.168.1.5 :
      															// ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"],
      															// or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format :
      															// ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
      	useHttps: false, 		// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "", 	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "", 	// HTTPS Certificate path, only require when useHttps is true
      I
      Ice-cream
      Sorry, that did not work - error I receive.
      code: ‘EADDRINUSE’,
      errno: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘[delete]’,
      port: 8090
      Yes MM auto-starts on reboot > yes to automated script > I followed these steps: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror.
      The current error when I run
      pm2 restart mm
      Use --update-env to update environment variables
      [PM2] Applying action restartProcessId on app [mm](ids: 0,1)
      [PM2] mm â
      [PM2] mm â
      ââââââ¬âââââââââââââââââââââ¬âââââââââââ¬âââââââ¬ââââââââââââ¬âââââââââââ¬âââââââââââ
      â id â name â mode â ⺠â status â cpu â memory â
      ââââââ¼âââââââââââââââââââââ¼âââââââââââ¼âââââââ¼ââââââââââââ¼âââââââââââ¼âââââââââââ¤
      â 0 â mm â fork â 0 â errored â 0% â 0b â
      â 1 â mm â fork â 1 â online â 0% â 1.8mb â
      ââââââ´âââââââââââââââââââââ´âââââââââââ´âââââââ´ââââââââââââ´âââââââââââ´âââââââââââ
      I’ve also run
      pm2 logs mm
      pi@raspberrypi:~ $ pm2 logs mm
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm | npm ERR! Failed at the magicmirror@2.12.0 start script.
      0|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|mm |
      0|mm | npm ERR! A complete log of this run can be found in:
      0|mm | npm ERR! /home/pi/.npm/_logs/2020-07-26T00_13_44_413Z-debug.log
      0|mm | npm ERR! code ELIFECYCLE
      0|mm | npm ERR! errno 1
      0|mm | npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|mm | npm ERR! Exit status 1
      0|mm | npm ERR!
      0|mm |
      0|mm | npm ERR! /home/pi/.npm/_logs/2020-07-26T00_36_04_600Z-debug.log
      I’ve just checked and I do not have a doc electron.js from this source - ./node_modules/.bin/electron js/electron.js.
      I remember that all I did was type kill in the terminal and killed a number - what mess have I caused!!! I’m so sorry :(
      The instructions I followed - I stopped after I entered kill and the number (I think mine began with a 5 or 9)
      I
      Ice-cream
    • RE: No numbers in analog watch face
      1. Haha thanks guys - that worked!
      Very good point in regard to ‘‘how you update the code if you don’t know to create custom.css?’’- I previouly edited the config.js, clock.js and clock_styles.css > I created a really pretty analog clock with the centre, second hand, minute and hour each with different colours.
      1. For some reason I thought that a custom.css was really technical but I easily created this from my terminal.
      For what it’s worth, I’ve connected to a few APIs and have configued these in the main confg folder and the css’s.
      Going forward I’m going to play with customising the default modules (well the ones which I haven’t hidden in the main config file) in the custom CSS.
      Thanks again Xx
      I
      Ice-cream
    • Error - EADDRINUSE
      Hi everyone, I’m new to MM and coding.
      Situation - when I ran , I received an odd note in my terminal (copied the below from Google).
      Error: listen EADDRINUSE: address already in use :::8080
          at Server.setupListenHandle [as _listen2] (net.js:1258:14)
          at listenInCluster (net.js:1306:12)
          at Server.listen (net.js:1394:7)
      I found some instructions online and then KILLED something in the terminal (again copied from Google):
      node 2464 murari 21u IPv6 4392639 0t0 TCP *:http-alt
      So I killed MY PID which was a different number and I’ve sort of fucked up my MM.
      When I run the MM, I receive this error now - could someone please help? Thank you Xx
      code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '[deleted]',
        port: 8080
      [2020-07-26 09:30:22.750] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-07-26 09:30:22.750] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-07-26 09:30:22.780] [LOG]    Launching application.
      ^C
      I
      Ice-cream
      @hango Thanks Hango.
      1. I have updated the code (still not working presumably because of point 3 below)
      2. I don’t know where to download the old SVG faces - when I installed MM there was/is a folder full of SVG clock faces
      3. Please don’t laugh - I don’t know how to create/use a custom css folder - I plan to learn this soon! X
      I
      Ice-cream
      @hango Hi again, I’ve modified my script but it isn’t working:
      .clockCircle {
      margin: 0 auto;
      position: relative;
      border-radius: 50%;
      background-size: 100%;
      background: transparent /home/pi/MagicMirror/modules/default/clock/faces(“faces/face-005.svg”) center no-repeat;
      In this context, is url an actual url or my fie path? x
      I
      Ice-cream
    • RE: Weather forecast - only displaying 3x days (? help)
      @hango, THANK YOU :) I have a question - how on Earth did you determine that line 297 from the file needed to be amended? Are you God? Are you a computer scientist? I am in awe of your eagle eye and intelligence! :clapping_hands: :blond-haired_woman: :call_me_hand:
      posted in General Discussion
      I
      Ice-cream
      @hango Thanks - I’ll try this tonight and revert with an update :) x
      I
      Ice-cream
    • RE: Default weather forecast only showing two days
      Hey everyone, I’m also experiencing this issue and went fucking crazy LOL! I can’t wait to try “Sparxx’s” recommendation. X
      I
      Ice-cream
    • Weather forecast - only displaying 3x days (? help)
      Hi everyone,
      My weather forecast’s only displaying three days and not the default 5 (or so). I’ve changed the fault to 7 days and still nothing. Changed the fade as I thought this was hiding the additional days. Nothing.
      I’ve cross-referenced my lines with those from the Weather module in GitHub and mine matches.
      I’d LOVE to display 7 days - and would love your help. Xx ice-cream (https://github.com/MichMich/MagicMirror/tree/master/modules/default/weatherforecast)
      I
      Ice-cream
