    No numbers in analog watch face
    33 Posts 11 Posters 16.5k Views 9 Watching
      A Former User
        JoeFranz
        Thats it, it works, thank you :thumbs_up:
        • MichMichM
          MichMich
          I just merged a fix into the develop branch. That should fix it.
          git checkout develop && git pull
          • N
            nagaculun
            @MichMich said in No numbers in analog watch face:
            I got error
            pi@MM:~/MagicMirror $ git checkout develop
            error: pathspec 'develop' did not match any file(s) known to git
            pi@MM:~/MagicMirror $ git pull
            Already up to date.
            pi@MM:~/MagicMirror $ git status
            On branch master
            Your branch is up to date with 'origin/master'.
            Untracked files:
            What should I do next ?
            S lavolp3L 2 Replies Last reply
              sdetweil @nagaculun
              @nagaculun did u use my install script?
              • lavolp3L
                lavolp3 Module Developer @nagaculun
                @nagaculun Odd.
                I have the same error message and
                git fetch origin
                git branch -a
                do not show the develop branch on remote
                git checkout -b develop origin/develop gives a fatal error:
                fatal: Cannot update paths and switch to branch 'develop' at the same time.
                Did you intend to checkout 'origin/develop' which can not be resolved as commit?
                Haven’t seen this before.
                @sdetweil have not used your install script
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  sdetweil @lavolp3
                  @lavolp3 interesting, my script tries to minimize space used, so only downloads the master branch
                  to down develop do
                  git fetch origin develop:develop
                  N T 2 Replies Last reply
                  • N
                    nagaculun @sdetweil
                    @sdetweil said in No numbers in analog watch face:
                    that works. thanks.
                    • I
                      Ice-cream
                      • I
                        Ice-cream @Guest
                        @hango Hi again, I’ve modified my script but it isn’t working:
                        .clockCircle {
                        margin: 0 auto;
                        position: relative;
                        border-radius: 50%;
                        background-size: 100%;
                        background: transparent /home/pi/MagicMirror/modules/default/clock/faces(“faces/face-005.svg”) center no-repeat;
                        In this context, is url an actual url or my fie path? x
                          A Former User
                          I 1 Reply Last reply
                            A Former User
                            • I
                              Ice-cream @Guest
                              @hango Thanks Hango.
                              1. I have updated the code (still not working presumably because of point 3 below)
                              2. I don’t know where to download the old SVG faces - when I installed MM there was/is a folder full of SVG clock faces
                              3. Please don’t laugh - I don’t know how to create/use a custom css folder - I plan to learn this soon! X
                                A Former User
                                  sdetweil @Guest
                                  @hango if one uses my installer script, I create the empty custom.css as part of the install.
                                  ? 1 Reply Last reply
                                    A Former User @sdetweil
                                    • I
                                      Ice-cream
                                      1. Haha thanks guys - that worked!
                                      Very good point in regard to ‘‘how you update the code if you don’t know to create custom.css?’’- I previouly edited the config.js, clock.js and clock_styles.css > I created a really pretty analog clock with the centre, second hand, minute and hour each with different colours.
                                      1. For some reason I thought that a custom.css was really technical but I easily created this from my terminal.
                                      For what it’s worth, I’ve connected to a few APIs and have configued these in the main confg folder and the css’s.
                                      Going forward I’m going to play with customising the default modules (well the ones which I haven’t hidden in the main config file) in the custom CSS.
                                      Thanks again Xx
                                        sdetweil @Ice-cream
                                        @Ice-cream do not edit the default files.
                                        config in config.js and css in custom.css
                                        • T
                                          TomBrown @sdetweil
                                          to down develop do
                                          I am probably doing something wrong.
                                          I typed in “git fetch origin develop:develop” and then “git checkout develop” and got an error.
                                          error: Your local changes to the following files would be overwritten by checkout:
                                          	modules/default/clock/clock.js
                                          	modules/default/weatherforecast/weatherforecast.js
                                          	package-lock.json
                                          Please commit your changes or stash them before you switch branches.
                                          Aborting
                                            sdetweil @TomBrown
                                            @TomBrown do u remember why you edited the clock and weatherforecast files?
