    No numbers in analog watch face
    33 Posts 11 Posters 13.9k Views 9 Watching
      JoeFranz
      Hi, since the update to 2.12.0 my anlog watch no longer has any numbers in the watchface.
      It is the default clock module. Is there a font missing?
      Jörg
        A Former User
          JoeFranz
          I know i set face-003 and didn’t change anything. No watchface is working since the update.
            A Former User
              JoeFranz
              Tried both, the watch remains without numbers :-(
              • lavolp3L Offline
                lavolp3 Module Developer @JoeFranz
                @JoeFranz I have the same issue. Also trying ‘face-003’. Have not tried another one yet.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • lavolp3L Offline
                  lavolp3 Module Developer @lavolp3
                  @lavolp3
                  Changing the face (tried face-004 and face-005) does not solve the issue.
                  Links to svgs seem correct…
                  • qu1queQ Offline
                    qu1que Project Sponsor
                    Same happens to me, after 2.12.0 MM update, only the clock hands are shown.
                    • BKeyportB Offline
                      BKeyport Module Developer
                      I’ve got it too. The faces are all missing. No big for me, I’ve gone back to digital only on that one to make room for another module.
                        A Former User
                          JoeFranz
                          Thats it, it works, thank you :thumbs_up:
                          • MichMichM Offline
                            MichMich
                            I just merged a fix into the develop branch. That should fix it.
                            git checkout develop && git pull
                            • N Offline
                              nagaculun
                              @MichMich said in No numbers in analog watch face:
                              I got error
                              pi@MM:~/MagicMirror $ git checkout develop
                              error: pathspec 'develop' did not match any file(s) known to git
                              pi@MM:~/MagicMirror $ git pull
                              Already up to date.
                              pi@MM:~/MagicMirror $ git status
                              On branch master
                              Your branch is up to date with 'origin/master'.
                              Untracked files:
                              What should I do next ?
                              S lavolp3L 2 Replies Last reply Reply Quote 0
                                sdetweil @nagaculun
                                @nagaculun did u use my install script?
                                • lavolp3L Offline
                                  lavolp3 Module Developer @nagaculun
                                  @nagaculun Odd.
                                  I have the same error message and
                                  git fetch origin
                                  git branch -a
                                  do not show the develop branch on remote
                                  git checkout -b develop origin/develop gives a fatal error:
                                  fatal: Cannot update paths and switch to branch 'develop' at the same time.
                                  Did you intend to checkout 'origin/develop' which can not be resolved as commit?
                                  Haven’t seen this before.
                                  @sdetweil have not used your install script
                                    sdetweil @lavolp3
                                    @lavolp3 interesting, my script tries to minimize space used, so only downloads the master branch
                                    to down develop do
                                    git fetch origin develop:develop
                                    N T 2 Replies Last reply Reply Quote 0
                                    • N Offline
                                      nagaculun @sdetweil
                                      @sdetweil said in No numbers in analog watch face:
                                      that works. thanks.
                                      • I Offline
                                        Ice-cream
                                        • I Offline
                                          Ice-cream @Guest
                                          @hango Hi again, I’ve modified my script but it isn’t working:
                                          .clockCircle {
                                          margin: 0 auto;
                                          position: relative;
                                          border-radius: 50%;
                                          background-size: 100%;
                                          background: transparent /home/pi/MagicMirror/modules/default/clock/faces(“faces/face-005.svg”) center no-repeat;
                                          In this context, is url an actual url or my fie path? x
                                            A Former User
