    MMM Binary Clock
    2 Posts 2 Posters 475 Views 1 Watching
    • N
      nikobix
      MMM-BinaryClock
      This is a module for the MagicMirror².
      https://github.com/nikobix/MMM-BinaryClock
      Re-written the module to remove the DOM rebuild every second. DOM is now built once and the images are blocked/unblocked.
      Removed the H-M-S as I just could not get them to align correctly when size changes.
      Using the module - moment.js
      To use this module, add the following configuration block to the modules array in the config/config.js file:
      var config = {
                  module: 'MMM-BinaryClock',
                  position:"top_left",
      If you want to change the graphics you can download any icon and save in img folder, then change ledOn and off names in start function
      Any issues let me know.
      Cheers
        A Former User
        This post is deleted!
