    Sweeping second hand on the clock?
    4 Posts 2 Posters 863 Views 2 Watching
    • L Offline
      lkthomas
      Is that possible to have a sweeping second hand like a mechanical watch on the built-in clock dial?
        sdetweil @lkthomas
        @lkthomas doc seems to imply u have that by default in analog mode, and u can set it’s (second hand) color different from hour/minute
        https://docs.magicmirror.builders/modules/clock.html#configuration-options
        • L Offline
          lkthomas
          I didn’t ask for second hand to change color, I am actually asking if the second hand could “Sweep” and not tick in 1 second interval
            sdetweil @lkthomas
            @lkthomas ah. I did not read that in your prior text. U will have to change the animation css to use many more smaller steps… caution, that will consume a lot of cpu power, and may not leave enough for other requirements on some processors
