    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 57.3k Views 5 Watching
      Michael Schw. @sdetweil
      @sdetweil thank you for the help btw!!!
      ok i figured out that my tv which i use as the display (Samsung LE-32 C530) has HDMI-CEC so i tried it with that and it works after i installed the cec module.
      its just a shame that the tv needs 15 seconds to boot (EVERYTIME!!) and i cant disable the pop up on start which shows the source and the hdmi port used.
      How can i stop the standby mode for the raspberry pi? because if the screen is off for a certain time and i turn it on again it shows me a blank black screen until i press a button or mouve the mouse (which i don want to have connected later on).
      How can i make the mirror to autostart on booting the raspberry?
      I have no shutdown command. Can i safley turn off the pi with this? and if yes, how do i get it?
      I really wanna make this thing work perfectly. i even thinking of adding an ir frame to make it touchscreen =)
        sdetweil @Michael Schw.
        @Michael-Schw if you don’t use pm2 you should, it will start at boot… if you didn’t install it with my scripted install, then use the fixuppm2.sh script from here
        just cut/paste that one line to run that script.
        shutdown and reboot are commands built in to linux
        sudo shutdown now (-r | -h, -r means reboot, -h means halt)
        sudo reboot , is the same as sudo shutdown -r
        turn off the pi screen saver, also see my screensaveroff script…
        (again if you had run my script as part of install, it would have prompted and done all this for you.
        my script is listed in the alternative install section of the MM doc)…
        none of my tvs support cec, so I created my own module for sleep (using a webcam for wakeup), it just hides all the modules,
        alexaControl supports that too (vgencmd:‘hide’)
        MMM-SleepWake
        my pis & tvs run 24x7
          @sdetweil thank you…you are a genius😁
          I installed that automated update now but how do i excactly turn the screensaver off…i cant find your script…do you have a link for that?
          And how can i start the mirror automaticly on boot of the raspberry? And is there any posibillity that the pi reboots itself if he needs it or should i just say it sometimes to alexa? Because if i let it run 24/7 it will at some time become really slow i think.
          So what do i have to add in the option pm2processname for the alexa module?
          Because refresh and monitor toggle are working but stop and restart isnt.
          And i dont have shutdown at my alexa devices for the mirror.
            @Michael-Schw i’m sorry, I do not understand…
            you do NOT ‘install’ anything from my scripts repo. you just execute the commands I have documented.
            to turn off the screensaver you copy/paste this one line to a terminal window on the pi
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
            to setup for start at boot, you run the pm2 script, the same way
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
            then you can also stop/restart the process
            pm2 status will tell u it anything is running
            pm2 start number| name
            will start that named process
            pm2 restart, stop, show, list, are other commands
            pm2 logs --lines=?? will show the terminal window output of the processes (?? is a number)
            pm2 --help will give u the syntax
            the alexaControl module needs the NAME of the pm2 process definition
             pm2 status
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 8    │ stopped   │ 0%       │ 0b       │
            │ 1  │ smart-mirror       │ fork     │ 35   │ stopped   │ 0%       │ 0b       │
            so for MM it would be whatever is listed for the name
            to change the name, u need to delete the entry (see the pm2 help for the syntax here)
            and create it again, after modifying the ~/MagicMirror/installers/pm2_MagicMirror.json file
            then rerun my fixuppm2.sh script again.
            the devices added by AlexaControl are defined in the translations/??.json file, here is the default en.json
                    "PAGE": "page ",
                    "REFRESH": "refresh",
                    "RESTART": "restart pm2",
                    "STOP": "stop pm2",
                    "REBOOT": "reboot pi",
                    "SHUTDOWN": "shutdown pi",
                    "MONITOR": "monitor",
                    "USB": "USB"
            so the devices are
             "refresh",
             "restart pm2",
             "stop pm2",
            "reboot pi",
             "shutdown pi",
             "monitor"
            remember these are electric outlet type devices, they can be on or off… that is all
            so the alexa voice syntax is
            alexa turn on (or off) device
            alexa turn on refresh
            alexa turn off monitor
            alexa turn on restart pm2
            etc
            • 6
            • 7
            • 8
            • 9
            • 10
            • 10 / 10
