    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 57.7k Views 5 Watching
      dave_ @sdetweil
      @sdetweil it’s finally showing on screen like the mm is working but still had no luck with discovery and Spotify is off
        sdetweil @dave_
        @dave_ did u see the startup messages from the module like i posted?
          dave_ @sdetweil
          @sdetweil alt text
          I am not quite sure which line to look at but check the image
          Just out of curiosity does it have to be alexa echo device like can’t a i use for a soundbar or speaker with built in alexa or maybe even the mobile app?
            sdetweil @dave_
            @dave_ u got the eaddressinuse error. something is using port 1900, this the the port we stopped Spotify to get access to
            stop mm, then do
            sudo netstat -a | grep 1900
            in there is a response then something is still using the port.
            I havent tried discovery from my Alexa app in a long time. since they made it possible via voice command
              dave_ @sdetweil
              @sdetweil alt text that’s what it says
                sdetweil @dave_
                @dave_
                ok do this
                sudo netstat -a -p | grep 1900
                mine shows this when MM is running
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           11153/electron.js
                  dave_ @sdetweil
                  @sdetweil ohh shit i had installed jellyfin media server ages ago and that’s what it’s saying how do i uninstall that 😂
                    sdetweil @dave_
                    @dave_ sorry, no idea… google might help
                      dave_ @sdetweil
                      @sdetweil lemme see and I’ll let u know
                        dave_ @sdetweil
                        @sdetweil can i just Change the ports? And then make ot work if yes what should i change it to
                        • 9
                        • 10
                        • 2 / 10
