    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 56.0k Views 5 Watching
      dave_ @sdetweil
      @sdetweil https://photos.app.goo.gl/SuvM64zPpyQCZjQT8
        sdetweil @dave_
        @dave_ ok, as expected… the extra image u posted this morning was from some other time
        now, if you do alexa discover devices (phone app is more (bottom right), other, discover devices)
          dave_ @sdetweil
          @sdetweil tried that still no luck
            sdetweil @dave_
            @dave_ ok, need to edit a file to turn on some debugging
            nano ~/MagicMirror/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js
            change lines 92-94, the console.log lines below
            change from
            	udpServer.on('message', (msg, rinfo) => {
            		//debug(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
            		//console.log('Search request from ' + util.inspect(rinfo));
            		//console.log(getMask(rinfo.address, '255.255.255.0'));
            to
            		console.log(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
              dave_ @sdetweil
              @sdetweil my internet went of for a bit I’ll do this asap and let you know!
                sdetweil @dave_
                @dave_ I also added another line of debug
                let response = function(ipaddr) {
                	let deviceresp = [];
                	let responses = [];
                	for(let i = 0; i < = devices.length - 1; i++) {
                		console.log('responding for port='+devices[i].port)   // this line
                and I see this output from the MM console , from alexa discover devices
                [2020-08-05 11:31:33.543] [LOG]    << server got: M-SEARCH * HTTP/1.1
                HOST: 239.255.255.250:1900
                MAN: "ssdp:discover"
                MX: 1
                ST: urn:dial-multiscreen-org:service:dial:1
                USER-AGENT: Chromium/78.0.3904.108 Linux
                 from 192.168.2.126:57706 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:93 Socket.<anonymous>)
                [2020-08-05 11:31:33.545] [LOG]    Search request from { address: '192.168.2.126', family: 'IPv4', port: 57706, size: 167 } (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:94 Socket.<anonymous>)
                [2020-08-05 11:31:33.548] [LOG]    192.168.2.0 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:95 Socket.<anonymous>)
                [2020-08-05 11:31:33.550] [LOG]    responding for port=16000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:33.552] [LOG]    responding for port=16001 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:33.553] [LOG]    responding for port=16002 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:33.553] [LOG]    responding for port=16003 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:33.553] [LOG]    responding for port=16004 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:33.553] [LOG]    responding for port=16005 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                (electron:23027): GLib-GIO-CRITICAL **: 11:31:34.172: g_dbus_proxy_new: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
                [2020-08-05 11:31:34.549] [LOG]    << server got: M-SEARCH * HTTP/1.1
                MX: 1
                [2020-08-05 11:31:34.549] [LOG]    Search request from { address: '192.168.2.126', family: 'IPv4', port: 57706, size: 167 } (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:94 Socket.<anonymous>)
                [2020-08-05 11:31:34.549] [LOG]    192.168.2.0 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:95 Socket.<anonymous>)
                [2020-08-05 11:31:34.550] [LOG]    responding for port=16000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:34.551] [LOG]    responding for port=16001 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:34.551] [LOG]    responding for port=16002 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:34.551] [LOG]    responding for port=16003 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:34.551] [LOG]    responding for port=16004 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                [2020-08-05 11:31:34.552] [LOG]    responding for port=16005 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                  Michael Schw.
                  Hey…
                  I have the same Issue and i will do every step i found here tomorrow.
                  I tried everything i found on the Internet but i still couldnt make it work.
                  You have any new knowledge here? I even heard somewhere that the fauxmo code wont work anymore because Alexa cant find the emulated Wemo Devices anymore. Btw Alexa Controll starts at port 11000 but when i set it to 1900 it still doesnt work.
                  I am currently at the step with disabling Spotify which didnt solve my Problem. So tomorrow i will try to make my Config.js file readable (because it looks terrible at the moment) and then i will post it here.
                  All i wanna do is to toggle my Display with Alexa…i dont need to switch Pages or hide modules. I just wanna turn it on and off. I found every Solution for every Problem i had myself except for this Problem.
                    sdetweil @Michael Schw.
                    @Michael-Schw I just added another system the other day without any issue.
                    I do have an original echo, a number of echo dots and one echo show.
                    but did the discovery from the Alexa app on my phone.
                      Michael Schw. @sdetweil
                      @sdetweil i tried it with the app on my fire tablet, the echo plus 2nd gen and the echo dot 3rd gen. The first gen echos are still working but the newer ones dont wanna work. So maybe we can figure something out or plan b would be a sonoff switch for the tv display . But maybe there is a way without the switch. Witch gen are your echos?
                        @Michael-Schw my echo is a gen 1, and dots are gen 2.
                        do u see the messages like I listed at mm startup? (from 5th post to this topic) also, would be startPort:19000 not 1900.
                        port 1900 is hard coded to the ssdp discovery port, used by Alexa to find devices
                        if u see the messages, and add the debugging from above, do u see the discovery request?
                        show me the mm startup.messages
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 8 / 10
