    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 57.7k Views 5 Watching
      dave_ @sdetweil
      @sdetweil yes i did still no luck i think I’ll just wait for a new module like this to come out and hopefully that’ll work
      Thanks for your help appreciate it
        dave_ @sdetweil
        @sdetweil actually take a look at this
        https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
          sdetweil @dave_
          @dave_ something is using the port again
          do this again
          sudo netstat -a -p | grep 1900
          D S 2 Replies Last reply Reply Quote 0
            dave_ @sdetweil
            @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
            No response
              @sdetweil in config.js add
              disabled: true,
              to the MMM_AlexaControl module def
                    module: 'MMM-AlexaControl',
                    disabled: true,          /// add this line
                     position: whatever,
                    config:{
              and restart MM, then in another window to the netstat -a -p command again
                sdetweil
                it is hard to help if you don’t respond
                  dave_ @sdetweil
                  @sdetweil sorry so i just did what u said and still the same like last time
                    sdetweil @dave_
                    @dave_ no response?
                    show me MM messages
                      dave_ @sdetweil
                      @sdetweil https://photos.app.goo.gl/QonL4x1TWAwagqnC6
                        sdetweil @dave_
                        @dave_ and while MM was running you were supposed to do the netstat -a -p commands to see if the process blocking port 1900 is inside MM…
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 6 / 10
