    OwnCloud integration
    Scheduled Pinned Locked Moved Unsolved General Discussion
    13 Posts 7 Posters 12.8k Views 7 Watching
    • J
      jan73
      I’d like to use OwnCloud as the calendar service for the MagicMirror, and would like to find out if there are others, that use OwnCloud as backend as well. Similarly OwnCloud could be used as a server backend for other data, like todo lists or even new feeds. I would like to understand if others also interesting in using OwnCloud.
      • P
        paviro
        Doesn’t Owncloud provide a ical url? You could use that without any problem in the calendar module :)
        – The Doctor
        • D
          DirkS
          as i can see in my owncloud they are providing CalDAV adresses. I’m not using the calendar function but should be no problem to integrate.
            Shampooman
            Hello,
            I would also like to sync the MM with my owncloud calendar. The bad news is, that you need a username and a password for the owncloud ical file. I didn’t find an option to enter a user and password in the MM-Modul. So I tried to do a workaround (this project is my first expirience with JS, so it’s pretty hard for me to understand.) I found a little bash script to download the ical file to my homefolder. But I can’t enter the homefolder location with the MM-Modul. Perhaps someone has a good idea to do this job. :)
            #!/bin/bash
            ical=‘http://ownclouddomain.de/remote.php/caldav/calendars/admin/blubb?export’
            dir=/home/pi/
            user=‘admin’
            pw=‘blablabla’
            curl $ical -u$user:$pw > $dir’MYical.ics’
              Shampooman
              I found another important information. It’s still very dirty, and everyone who knows how to do something like this will just laugh about me, but I got a working way to import my owncloud calendar. I just changed the directory to /home/pi/MagicMirror/modules/default/calendar/public
              and added the following to the config.js:
                                                          symbol: 'calendar-check-o ',
                                                          url: 'http://127.0.0.1:8080/calendar/MYical.ics'
              this is my bash script now:
              #!/bin/bash
              ical='http://ownclouddomain.de/remote.php/caldav/calendars/admin/blubb?export’
              dir=/home/pi/MagicMirror/modules/default/calendar/public
              user='admin’
              pw=‘blablabla’
              so you only have to make a cronjob now, which starts the bash script.
              I hope this helps someone, even if it is very, very dirty… :)
              • P
                paviro
                Why not do username:password@yourdomain.com in the config?
                – The Doctor
                  Shampooman @paviro
                  @paviro said in OwnCloud integration:
                  because it doesn’t work. :) I got this Error in the console:
                  logger.js:23 Calendar Error. Could not fetch calendar: user:password@myowncloud.de/remote.php/caldav/calendars/user/calendar?export
                  • P
                    paviro
                    Can you try executing curl -L http://user:password@myowncloud.de/remote.php/caldav/calendars/user/calendar?export in a shell?
                    – The Doctor
                      Shampooman
                      hmmm… that works…
                        Shampooman
                        ok, now it works completly. Perhaps I had a mistake inside my code. Thank you for your help!
                        • C
                          charliwest
                          @Shampooman do you have this publicly anywhere? I have a bash script that does something I want an MMM to do but have no idea how to get it working and it looks to me thats what you are doing.
                            A Former User
                            I can make the curl call work, adding a -k to it, to get around the certificate.
                            Can I do something similar in the module ?
                            Thanks.
                            • R
                              raymonvdm
                              I`m using NextCloud and i figured it out using the following config
                                                  header: "username",
                                                           symbol: "calendar-check-o ",
                                                           url: "https://username:app_password@nexctcloud.domain.nl/remote.php/dav/calendars/username/8a757113-03ae-4d7a-a6a1-8db4350eee54_shared_by_username?export"
                              I got the calander name from the webinterface by clicking on the dots right behind the specific calender.
                              Note: I am using a dedicated user to login to nextcloud. This user is recieving the “shared” calanders from the actual users. In this way i don`t need to login with my own nextcloud credentials
