    MMM-NetworkScanner (spitzlbergerj)
    7 Posts 4 Posters 2.2k Views 4 Watching
      MiPraSo
      I need some help with the configuration of MMM-NetworkScanner, published by spitzlbergerj
      I’d like to see that view:
      alt text
      I’ve made some attempts to configure it, but I can’t get this view.
      Does anyone have a working config and can publish it here?
      Thanks for the help!
        sdetweil @MiPraSo
        @MiPraSo I don’t know, but what do you get from your config?
          MiPraSo
          That’s what I see:
          Technically it works, but the colors and formatting are not correct.
          • karsten13K Offline
            karsten13
            from your output it looks like your using https://github.com/spitzlbergerj/MMM-NetworkScanner#simple-example and not the example with columns.
              MiPraSo
              I found the clue.
              In the description is the wrong path for cloning is given:
              :cross_mark: git clone https://github.com/ianperrin/MMM-NetworkScanner.git
              It has to be:
              git clone https://github.com/spitzlbergerj/MMM-NetworkScanner.git
              Now it works as expected!
                sdetweil @MiPraSo
                @MiPraSo yes, always use the button to get the download link. as many repos are forks (linked duplicates)
                when I fork someone repo, I don’t update the doc, as I assume the author will take my updates, and then HIS original doc would be wrong.
                  Sebi76 0
                  Hello,
                  i use this Module an im very Happy with it.
                  The Problem is i run for my firsttime MM under Ubunt.
                  In the Start Script from MM i had to type in my Passwort otherwise the module will not start and the list will remain empty. I think the arp-scan needs Sudo Rights which are not passed through, is my guess.
