    Monitor says "NO SIGNAL"
    14 Posts 4 Posters 3.6k Views 4 Watching
      Ameyalgudkar @sdetweil
      @sdetweil haha yeah even I am not sure what did I do wrong or where. because the monitor used to work fine everything was working well, but this just happened suddenly. Maybe I will just use this monitor on RPI from now on.
      Also, I am using it with a DVI to HDMI cable and to micro HDMI. could it be due to any of those reasons?
      and I tried removing the DVI and inserting it back as well but that did not work as well.
        sdetweil @Ameyalgudkar
        @Ameyalgudkar hm… i use dvi/hdmi adapter on one monitor, but again, never seen monitor locked to one system, or signal.
        now… I HAVE seen one system locked to specific config…
        I have to power off/on my pi4 if I want the second display to work… only recognized at power on…
          @sdetweil well, thank you for the time I appreciate it. and hope you find a solution in future for this.
          • Jefferjames87J Offline
            Jefferjames87
            Hello,
            Is your problem is solved?
            Recently, I am also facing the same issue, I tried to contact the customer care service of the monitor.
            Later I released, I am using the outdated drivers and hence it is creating the issues to display the pictures. I think you have the same scenario. I am linking to the resource, you can check them for step by step troubleshoot.
            Thanks,
            Jeffer James
