    Changing IP adresses
    changing ip addresses
    18 Posts 4 Posters 4.8k Views 4 Watching
    • N6NGN Offline
      N6NG
      I had to change my wireless router. When I dd and rebooted the MagicMirror it can’t see the new wireless system.
      It was working fine with the old routing information when I set it up initially. What do I have to do to get it back on the new address? I tried adding the new address for the new wireless address to the config.js file as described, but it did no good. It still doesn’t see it… Any suggestions?
      Thanks all of you with smarts out there
      Dennis N6NG
        sdetweil @N6NG
        @N6NG there should be nothing about the real network in config.js
        address:"0.0.0.0",
        ipWhitelist:[],
        did the SSID of the network change? use the network widget on the raspi desktop, next to the date/time, top right.
        to minimize mm, in case it’s up, alt-spacebar, n
        • N6NGN Offline
          N6NG
          Thanks… I’ll let you know…
          Dennis
          • N6NGN Offline
            N6NG
            That didn’t help… And yes the SSID changed
            Dennis
            • bheplerB Offline
              bhepler Module Developer
              I’m a little confused. Is your Rpi on your wireless network at all? Can you use the web browser on your Pi to pull up a website?
              It sounds like your Pi isn’t playing well with your new router. If you minimize the MM interface and click on the Wifi symbol in the top right of your mirror, you should be able to select the new SSID and enter the password to get onto the network. Did your Wifi network password also change?
              • N6NGN Offline
                N6NG
                No… I can’t connect to any web pages… It just say it can’t find the page I requested…
                Dennis
                • N6NGN Offline
                  N6NG
                  Doesn’t show the Ssid box in the corner… Just the bluetooth keyboard and the sound speaker and the time. which is incorrect…
                    sdetweil @N6NG
                    @N6NG go to the menu, upper left, then preferences, network
                    • N6NGN Offline
                      N6NG
                      Doesn’t show the Network option … Just the Raspberry Pi Configuration. When I choose; that option, I have an Interfaces option. I pick that one and have several options to enable and disable. One of which is SSH which I enable and it doesn’t do me any good.
                      I’m running the Debian version…
                        sdetweil @N6NG
                        @N6NG open terminal on pi, (ctrl-alt-t) and then sudo raspi-config, network options
                        N6NGN 1 Reply Last reply Reply Quote 0
