    Config file missing but no syntax errors?
    8 Posts 3 Posters 1.2k Views 3 Watching
    • W Offline
      Wenike
      This post is deleted!
        sdetweil @Wenike
        @Wenike can u post the error?
        • W Offline
          Wenike
          Its the standard image or text when launching MagicMirror of no config file being installed. I don’t know how to take a screenshot on the Pi, so camera picture it is!
          No config file error
            raymondjspigot
            Hi @Wenike in your MMM-Carousel config it looks like you have
            mode: global,
            which might need to be quoted? i.e.
            mode: 'global',
            S W 2 Replies Last reply Reply Quote 1
              sdetweil @Wenike
              @Wenike on the console where u did npm start.
                sdetweil @raymondjspigot
                @raymondjspigot good catch!
                I copied the config and this is the cause
                i also noted that the checker didn’t find this,
                not sure why…
                  sdetweil @Wenike
                  @Wenike the general rules for config.js
                  for the value to the right of :
                  numbers and true/false are not quoted,
                  everything else is, doesn’t matter which type, single or double, as long as they match
                  for the trailing comma on a line,
                  if the next line starts with a word, then this line needs a trailing comma (more coming)
                  • W Offline
                    Wenike @raymondjspigot
                    @raymondjspigot Thanks! That fixed it!
