    Executing python in js - troublshooting/development
    18 Posts 2 Posters 2.4k Views 2 Watching
    • beejay22B Offline
      beejay22
      Hi. I’m very new to coding and I have a pyscript that simply prints out the latest titles from a website using BeautifulSoup. However, when I launch magic mirror it’s just a black screen. I deleted all other modules besides my own in the config file so that it’s just my module that runs. I’ve done ample research and can’t seem to figure out what’s going on (updated mm software, reinstalled dependencies in the css directory just in case it wasn’t installed correctly, checked to see node was up to date - v10.21.0, etc.). I’m starting to think it may be my pyscript but it runs correctly in the console (I can attach my pyscript if needed). I’m not sure what the problem is so I appreciate any and all help!
      Core module: MMM-Whitehouse
      Module.register("MMM-Whitehouse", {
        getDom: function() {
          var e = document.createElement("div")
          e.id = "DISPLAY"
          return e
        notificationReceived: function(notification, payload, sender) {
          switch(notification) {
            case "DOM_OBJECTS_CREATED":
              var timer = setInterval(()=>{
                this.sendSocketNotification("GIVE_ME_DATA")
              }, 1000)
              break
            case "HERE_IS_DATA":
              var e = document.getElementById("DISPLAY")
              e.innerHTML = payload
              break
      node_helper.js
      const spawn = require("child_process").spawn
      var NodeHelper = require("node_helper")
            case "GIVE_ME_DATA":
              this.job()
              break
        job: function() {
          var process = spawn("python", ["/home/pi/Desktop/realTester.py"])
          process.stdout.on("data", (data)=>{
            console.log(data)
            var result = String.fromCharCode.apply(null, new Uint16Array((data)))
            this.sendSocketNotification("HERE_IS_DATA", data)
      config.js
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
       			module: "MMM-Whitehouse",
        			config: {}
      Error message (from dev mode):
      Initializing MagicMirror.
      translator.js:202 Loading core translation file: translations/en.json
      translator.js:225 Loading core translation fallback file: translations/en.json
      loader.js:179 Load script: modules/MMM-Whitehouse//MMM-Whitehouse.js
      module.js:479 Module registered: MMM-Whitehouse
      loader.js:150 Bootstrapping module: MMM-Whitehouse
      loader.js:155 Scripts loaded for: MMM-Whitehouse
      loader.js:157 Styles loaded for: MMM-Whitehouse
      loader.js:159 Translations loaded for: MMM-Whitehouse
      loader.js:194 Load stylesheet: css/custom.css
      (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
      loader.js:203 Error on loading stylesheet: css/custom.css
      module.js:46 Starting module: MMM-Whitehouse
      main.js:474 All modules started!
      /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
        protocols.This exposes users of this app to unnecessary security risks.
        Consider loading the following resources over HTTPS or FTPS.
       - http://localhost:8080/css/main.css
      - http://localhost:8080/fonts/roboto.css
      - http://localhost:8080/socket.io/socket.io.js
      - http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
      - http://localhost:8080/js/defaults.js
      - http://localhost:8080/config/config.js
      - http://localhost:8080/vendor/vendor.js
      - http://localhost:8080/modules/default/defaultmodules.js
      - http://localhost:8080/js/logger.js
      - http://localhost:8080/translations/translations.js
      - http://localhost:8080/js/translator.js
      - http://localhost:8080/js/class.js
      - http://localhost:8080/js/module.js
      - http://localhost:8080/js/loader.js
      - http://localhost:8080/js/socketclient.js
      - http://localhost:8080/js/main.js
      - http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
      - http://localhost:8080/translations/en.json
      - http://localhost:8080/modules/MMM-Whitehouse//MMM-Whitehouse.js
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
       This warning will not show up
      once the app is packaged.
      /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
          Policy set or a policy with "unsafe-eval" enabled. This exposes users of
        sdetweil @beejay22
        @beejay22 I copy/pasted your code, and only see a black screen cause there is nothing to display…
        there is a bug in the node_helper
                console.log("received notification")
                this.job()
                break
          job: function() {
            // type A, you specify the pgm to execute your script HERE
            var process = spawn("python",["/home/sam/Desktop/realTester.py"])
            // type B, you specify the pgm to execute your script IN the script.
            var process = spawn("/home/sam/Desktop/realTester.py")
              console.log(data)
              var result = String.fromCharCode.apply(null, new Uint16Array((data)))   // < --- you processed data to result
              this.sendSocketNotification("HERE_IS_DATA", data)    // < ---- then sent data, which is still a 'buffer'
        i fixed to this
                this.job()
                break
          job: function() {
           //  I prefer this , before u needed two things, python and the script..
           // but if u changed the script to bash, or java, or whatever, then the app would break..
              console.log(data.toString()) // debugging, log string
              //var result = String.fromCharCode.apply(null, new Uint16Array((data)))
              this.sendSocketNotification("HERE_IS_DATA", data.toString())   // pass the string, module expects string
        the script for example is
        #!/usr/bin/python3
        print("hello");
        • beejay22B Offline
          beejay22
          Thanks for the insightful reply! I changed my node_helper to what you posted:
                  this.job()
                  break
            job: function(){
              var process = spawn("/home/pi/Desktop/realTester.py")
          However, when I changed it I got an error message in the terminal which hasn’t happened before. Error message in terminal:
          [2020-08-23 22:36:26.161] [ERROR]  Error: spawn /home/pi/Desktop/testing.py EACCES
              at Process.ChildProcess._handle.onexit (internal/child_process.js:264:19)
              at onErrorNT (internal/child_process.js:456:16)
              at processTicksAndRejections (internal/process/task_queues.js:84:9) {
            errno: 'EACCES',
            code: 'EACCES',
            syscall: 'spawn /home/pi/Desktop/realTester.py',
            path: '/home/pi/Desktop/realTester.py',
            spawnargs: []
          [2020-08-23 22:36:26.171] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-08-23 22:36:26.172] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [2020-08-23 22:36:27.069] [LOG]    received notification
          [2020-08-23 22:36:27.094] [LOG]    Whoops! There was an uncaught exception...
          Still getting the same error log in the magic mirror using dev mode though… lastly this is my pyscript, realTester.py:
          from bs4 import BeautifulSoup
          import requests
          url=requests.get("https://www.whitehouse.gov/presidential-actions/")
          src=url.content
          soup = BeautifulSoup(src, 'lxml')
          for h2_tag in soup.findAll('h2'):
              a_tag = h2_tag.find('a')
              print(a_tag.string)
            sdetweil @beejay22
            @beejay22 sorry
            2more things.
            1. u need to add the 1st line to the script to tell the system what processor to use
            #!/usr/bin/python
            1. u need to make the script executable
            chmod +x /home/pi/Desktop/realTester.py
            • beejay22B Offline
              beejay22
              Okay so now my pycript looks like this:
              #!/usr/bin/python
              import requests
              src=url.content
                  print(a_tag.string)
              If I’m my understanding correctly, adding this shebang line lets shell know that my src code is a script, the type of interpreter we want to use and the path of said interpreter…
              Also am I suppose to execute chmod +x /home/pi/Desktop/realTester.py in shell? If so how and when… sorry I’m still trying to understand how exactly to do all of this
                sdetweil @beejay22
                @beejay22 yes, you need to execute the chmod command once, to mark the python script as executable. do this on a terminal window, or ssh session window
                ANY file in Linux can be executable.
                if you try to spawn/exec a file which does not have the execute permission set, u get the access error. it is not even opened.
                once the bit is set, then it is searched for the shebang, if present the identified file is exec’d and the rest of the parms are passed on.
                • beejay22B Offline
                  beejay22
                  Hmmm I did this in the terminal:
                  $ chmod +x /home/pi/Desktop/realTester.py
                  Nothing changed… still the same error log message… I think there’s something wrong with my custom’s css file since it says it’s not loading… in my css folder there’s only a main.css file there
                    sdetweil @beejay22
                    @beejay22 so, can u run the script from the terminal like before
                    python /home/pi/Desktop/realTester.py
                    and then /home/pi/Desktop/realTester.py
                    both should work, produce the same results
                    that $ wasn’t part of the chmod
                    • beejay22B Offline
                      beejay22
                      I didn’t add the $ to the command, I just said that in my post for clarity lol. I typed just this in the command line:
                      And yes I can run my script in the terminal with “python3 /home/pi/Desktop/realTester.py” but not with “/home/pi/Desktop/realTester.py” because the module I’m using in my script includes bs4 which is available with python3 I believe so I have to say python3
                      I also tried ‘touch ~/MagicMirror/css/custom.css’, still showing same error log
                        sdetweil @beejay22
                        @beejay22 u can run python3 as the shebang. I was just giving example
                        your node_helper code was spawning python, not python3. I just copied what u did. u can put python3 in the spawn as well
                        custom.css, doesn’t matter, it’s empty so no harm
                        • beejay22B Offline
                          beejay22
                          Tried this (all I changed was “python” to “python3”):
                                  this.job()
                                  break
                            job: function() {
                              var process = spawn("python3", ["/home/pi/Desktop/realTester.py"])
                                console.log(data)
                          And also changed pyscript to this (just added python3 to the shebang):
                          #!/usr/bin/python3
                          import requests
                          src=url.content
                              print(a_tag.string)
                          Also tested “python” again (not python3) in my node_helper along with the updated shebang as shown above
                          If custom.css file doesn’t matter I wonder why it’s giving this error… Have no clue what’s going on now lol
                            sdetweil @beejay22
                            @beejay22 u need the fix for the data conversion… as well…
                            custom.css cause its a file t=hat MM force loads, and while the browser is unhappy (thus the error), the MM runtime doesn’t care WHY there was no data, missing file, empty file, don’t care there were no css updates…
                            i don’t do python so I can’t help much…
                            but you gotta put in the fixes I gave you for data…
                            • beejay22B Offline
                              beejay22
                              Sorry I copied the wrong node_helper.js file in my last post. This is how it looks like now:
                              //node_helper.js
                                      this.job()
                                      break
                                job: function() {
                              I was trying to test if I can at least print something to magic mirror without a pyscript… node_helper looks like this:
                              //node_helper.js
                                      this.job()
                                      break
                                job: function() {
                                  var process = spawn("python3", ["/home/pi/Desktop/test.py"])
                                    data= "Hello World";
                              Hello World appears on MagicMirror but the test file that’s provided in the path (the test file just has: print(“this works”) does not so I’m not sure why I need to provide var process spawn if Hello World prints by itself… Anyways, I’m aware that there’s other ways to execute the child process however I’m not familiar with it. Please correct me if I’m wrong but can exec work in this situation as well? (pyscipt just prints out the latest titles when magic mirror restarts). I’m trying anything and everything at this point
                              And I added the default and start function to my core module although I don’t think I have to use it. This is how it looks like now:
                              /// MMM-Whitehouse.js - Core Module
                                defaults: {},
                                start: function () {},
                                  e.id = "DISPLAY"
                                  return e
                                      }, 1000)
                                      break
                                      break
                                sdetweil @beejay22
                                @beejay22 I don’t understand why u have trouble.
                                the 3 files I posted work together as u designed.
                                does your spawn(‘/use/bin/python’, [execname]) work to return the data.
                                console log to see
                                spawn and exec have different methods of returning the data. see the doc
                                Google search nodejs process spawn
                                • beejay22B Offline
                                  beejay22
                                  Did you try it with the pyscript? Or are you talking about it the core module, node_helper and config?
                                  And okay
                                    sdetweil @beejay22
                                    @beejay22 I am only working on inside MagicMirror
                                    the spawn on.data() gets called when the pgm launched outputs to stdout. my print hello
                                    of course I made sure the python script worked both ways, before showing that
                                    • beejay22B Offline
                                      beejay22
                                      Okay. And yes it does return the data as output I believe
                                        sdetweil @beejay22
                                        @beejay22 do you see this output from the node_helper in the terminal window where you do npm start?
                                        from your python script
