    MMM-AVStock v2.0.0 (npm update required!)
    14 Posts 6 Posters 6.7k Views 8 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      Based on @Sean 's MMM-AVStock, which I have taken over from him, I present you now version 2.0.0
      As the previous version it comes with a ticker and table mode, now it is possible to add a chart, or use chart mode to only show it.
      Additional features:
      • TOUCH MODE. Touch on a ticker / row to show the chart
      • VOLUMES: Daily Trading volumes.
      • TECHNICALS: Include EMA’s or SMA’s. As many as you want.
      • ZOOMABLE CHART. Yes. Zoomable.
      Now go and BTFD!
      There’s one downside at the moment:
      The data sourced from Alphavantage gets only updated once at the and of a trading day. So you always have the last session’s values.
      I’m working on a new source.
      Install
      Find the module here and have fun:
      [card:lavolp3/MMM-AVStock]
      https://github.com/lavolp3/MMM-AVStock
      or install directly, cause you just can’t wait any longer!
      cd ~/MagicMirror/modules
      git clone https://github.com/lavolp3/MMM-AVStock
      cd MMM-AVStock
      npm install
      Updates:
      NOTE! ALL CURRENT USERS OF THE MODULE NEED TO DO AN npm install AFTER UPDATING!
      git pull
      npm install
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil
        cool… what charting tool are you using?
        • lavolp3L Offline
          lavolp3 Module Developer @sdetweil
          @sdetweil Highcharts. Quite cool! They have a stockchart mode.
          I learned today ther’s even an ‘organization chart’ mode.
            sdetweil @lavolp3
            @lavolp3 thanks
            • E Offline
              etayl
              I want to follow a stock from Korean stock market. For example, Samsung.
              I found its symbol to be something like 000053.SK but it seems that the stock price isn’t being updated.
              Can you know what’s the problem?
              Thanks,
              Etay
              • lavolp3L Offline
                lavolp3 Module Developer @etayl
                @etayl Try the stock search function
                https://www.alphavantage.co/query?function=SYMBOL_SEARCH&keywords=Samsu&apikey=kxxxxxxxxxx
                Funnily it apparently works with any given API key.
                Here I can only find Samsung Frankfurt and London quotes.
                • lavolp3L Offline
                  Small update on new API.
                  I am working on including IEX Cloud API. Have been successful for quotes.
                  However the API has a limit for their free tier (as they all have) and requesting historic prices comsumes a LOT of usage quota.
                  For the charts to show we need this historical data however.
                  I am considering using both sources for the different purposes (i.e. IEX for quotes and AV for historic data).
                  So users would need 2 API keys for the complete module or one if they don’t want to see the chart.
                  If anyone has a better idea and knowledge about the API, let me know!
                  Have a great weekend everyone!
                  • C Offline
                    cml @lavolp3
                    @lavolp3 said in MMM-AVStock v2.0.0 (npm update required!):
                    nd
                    Do you think you will work on fixing the API? or letting it go since it’s now behind a payall. Loved it while it lasted regardless!
                    • C Offline
                      cml @cml
                      @cml For anyone looking for a fix, found on github via user “SleipnirMS”
                      "When using chartInterval = daily, you have to set it to “daily_adjusted” and replace both “daily” entries in node_helper.js to “daily_adjusted”.
                      Then it uses the free api part and everything is fine again."
                      lavolp3L 1 Reply Last reply Reply Quote 1
                      • lavolp3L Offline
                        lavolp3 Module Developer @cml
                        MMM-AVStock has been REANIMATED!
                        I have pushed a branch that uses the yahoo finance API and leaves Alphavantage behind for good.
                        Config should work as before, so anyone who wants to test, please let me know how it works!
                        You don’t need any new API Key!
                        • C Offline
                          cml @lavolp3
                          @lavolp3 New branch works great! Thanks for updating this!
                          • lavolp3L Offline
                            Thanks!
                            I still need to work on the ticker and update the readme. Hope I can get this done in the next weeks.
                              rmcelwee
                              I’m looking for a little help to make my chart look better. I’m only interested in one stock so that is all I am displaying. I notice the docs say the chart is only 90 days but the examples show 4 or 5 months. Anyway to increase past 90 days? OR, is there anyway to get the chart to stretch the 90 days out so it takes up the width of my vertical monitor? Anyway to get the months listed at the bottom of the chart? Any suggestions on how to make the chart look better? Thanks!
                              FWIW, I had a hard time getting this to run. The solution for me was to get version 18 of node running (someone else mentioned this). I was too dumb to do this until I found this webpage: https://pimylifeup.com/raspberry-pi-nodejs/
                              Also, mode : “chart”, did not work for me (showed a blank page).
                                rmcelwee @lavolp3
                                Anyone??? I’ll bump this to see if anyone can help. There has to be a way to get the chart to look better than this.
