custom.css not executed on return from GoogleAssistant. MMM-GoogleAssistant
google assistant
23 Posts 4 Posters 5.2k Views 3 Watching
  • G Offline
    gelaw @sdetweil
    @sdetweil Thanks! I see it now. Here is what I found:
    When I start MM:
    When I access GoogleAssistant:
    When the system exits GoogleAssistant and returns to MM the modified element.style persists and the position remains “fixed”.
    S 1 Reply Last reply Sep 2, 2020, 2:57 PM Reply Quote 0
      sdetweil @gelaw
      @gelaw very interesting… @Bugsounet what do you think? is iframe causing this?
      • G Offline
        gelaw
        @Bugsounet Thanks! When I navigate to the location that you posted it do not see an entry for custom.css. Perhaps I have it in the wrong location? Or I missed a setting to activate this in GoogleAssistant or Assistant2Display?
        my custom.css file is simply:
        and it it located at /home/pi/MagicMirror/css
        ? 1 Reply Last reply Sep 2, 2020, 7:52 PM Reply Quote 0
        • ? Offline
          A Former User
          This post is deleted!
          G 1 Reply Last reply Sep 2, 2020, 3:22 PM Reply Quote 1
          • G Offline
            gelaw @Guest
            @hango said in custom.css not executed on return from GoogleAssistant. MMM-GoogleAssistant:
            maybe help this:
            position: absolute !important;
            YES! That fixed my issue. Thanks!
            G 1 Reply Last reply Sep 2, 2020, 6:45 PM Reply Quote 0
            • G Offline
              gelaw @gelaw
              @gelaw said in custom.css not executed on return from GoogleAssistant. MMM-GoogleAssistant:
              maybe help this:
              @Bugsounet This made my display work, but it really is a brute force method. There must be a better solution. I still wonder what I missed in my original approach.
              • ? Offline
                A Former User
                It’s not a brut force … it’s because i use iframe
                but Really, I don’t know who can have some problem like that
                G 1 Reply Last reply Sep 2, 2020, 7:35 PM Reply Quote 0
                • G Offline
                  gelaw @Guest
                  @Bugsounet ok. Thanks!
                  • ? Offline
                    A Former User
                    @gelaw : if you want, give me a copy of your custom css … I want to inspect for fix GA (in private)
                    S 1 Reply Last reply Sep 2, 2020, 7:46 PM Reply Quote 0
                      sdetweil @Guest
                      @Bugsounet tiny custom.css back a few posts. only for clock
                      • 2 / 3
                      2 / 3
