    PIR sensor Disaster
    pirpir sensor
    6 Posts 2 Posters 2.0k Views 2 Watching
      delecive
      After wiring my sensor and following the instructions using MMM-PIR-Sensor, I must have made a mistake as it doesn’t work and only shuts of the HDMI port. The problem is, I have the program on auto start and am un able to fix the program as when it starts it proceeds to shut of the monitor making it so I’m unable to fix it. Is there anyone that can help?
        sdetweil @delecive
        @delecive is it turning off the monitor or the hdmi port? do you have ssh enabled?
        if monitor, unplug the monitor, let it boot up, then connect.
        if u have ssh enabled, I assume u are using pm2 to autostart, them do
        pm2 stop 0
        pm2 save
        sudo reboot
          delecive
          @sdetweil It shuts of the hdmi port which is problematic. I am able to open terminal and type things but that’s all as I only have a split second before the program boots up
            sdetweil @delecive
            @delecive yeh. ssh enabled?
              delecive @sdetweil
              @sdetweil after trial and error I was able to enter the command to turn back on the display port
                sdetweil @delecive
                @delecive woohoo!
